Hello,
I'm looking for some help. I have a vx-921 radio that I have successfully programmed but it won't transmit on channels that programmed as repeated (duplex) channels. All simplex channels work perfectly fine. I do have the toggle switch on top programmed for talkaround mode but that has been tested and is not the culprit. Also, the PL/sub audio tones are programmed correctly as well. Finally, when I do push the PTT button, the red light comes on indicating that it is attempting to transmit but nothing comes over. It receives on the repeated channels just fine.
Some other notes:
1) The repeater(s) are up and running.
2) I have taken the same codeplug and put it into another radio and that radio works perfectly fine.
Any help would be greatly appreciated. Thank you!
Some other notes:
