VXR9000 & CE60 software
rule308
I have a vxr9000 UHF repeater that I bought used and ce60 software & cable. I am able to read the programming but not able to access the alignment portion of the program. I have followed the software and service manual instructions, but it does not work. Does anyone have a clue about this?
Thanks, DB
MBill
VXR-9000 Dealer Mode for alignment
Try this: Go to the DOS command prompt. Change to the folder where your CE60.exe is stored.
Type in (without the quotes) "CE60Win.exe \D". That works for me in Windows 7. You can not
access the manufacturers drop down menu, but you now should be able to access the dealers
menu which has the alignment information.
Bill
PS: You may have to try CE60.exe \D depending on your Windows version, etc.
MBill
VXR9000
Correction on command prompt line. Change \D to /D. (I get forward/backward slash mixed up)
Also you can do this from the run command if you put in the complete path to CE60win.exe and then
add a space and /D
Bill
