KK4ELO
I bought a 354 after the 180 I bought turned out to be bad. When I first got it, I done a test run putting 5 freqs in. Everything good, took the programming fine. Went on to finish the rest of my file, then went to write the whole file and bam. Hardware mismatch error. Can't even read the radio. I went to this thread http://forums.radioreference.com/vertex-standard/99398-programming-vertex-vx-350-w-ce86-2.html and followed the past with the driver info. No go. Still the same problem. Originally I used the prolific driver for my vx7 for the first write. Then it wouldn't work again. I used the USB cable from WISCOMM but the driver cd that came with it wouldn't install. It's like I don't even have a disc in it. Anybody got any ideas to try?
