eportel6607
Guys I have over twenty VX-4000L Vertex mobiles. I also have about ten VX-5500L. I recently switched between CTCSS squelch to DCS. When transmitting and testing on the VX-5500 radio the system/network worked fine however when I transmit using the VX-4000L the system doesn't function. The programming is exactly the same on both radios. I've tested with Motorola equipment as well and I am now sure the issue is that the VX4000 radios are not encoding the DCS code. I've tried three or four different DCS codes. None of which are being encoded from the radio. The radio(s) do however decode each of the DCS codes I've tried. Is anybody aware of many something in the software that toggle the encoding on/off for this radio? The radio software has an obvious enable/disable for this feature just like every option in the radio but none of the VX4000s I've tried will encode DCS...just CTCSS.
Any input would be much appreciated.
It looks like the issue might be related to the polarity of the DCS coding. Anybody know how to toggle the codes to be "normal" or "invert"?
