artb257
Hello all
I am trying to reprogram my VX4000 (UHF) radio and am running into some difficulty. I am using a Windows 7 laptop with the CE49 software installed. The radio is connected to the computer with a CT 105 cable and FIF10A USB interface (with the driver software installed). In the software, I click on upload. I am prompted to put the radio in "PC Clone" mode by holding the PF1 button while turning on the radio, which I do. The software starts to read the radio, but then I get the following error message:
“The transceiver does not correspond to the band you try to write”
Make sure the following points.
1. COM port configuration
2. Cable connection with PC
3. Frequency band of the radio
4. firmware version
5. Deck model
My response to the points:
1. I have it correctly set up on COM port 3
2. All cable connections are secure
3. I manually set the band to "UHF D" in the software
4. Unknown - no way to check it and it's not showing on the software
5. Not applicable
Anyone have any thoughts? I feel like it's just a matter of one setting that is off or something wasn't activated or turned on in the proper order.
Thank you for any assistance.
Arthur
4. firmware version
5. Deck model
5. Not applicable
Arthur
