Vertex standard FVP-36 encryption
topcatim
I have some Vertex standard VX 354 radios that I am planning to re-program to use the PMR446 public frequency however they are fitted with the FVP-36 voice inversion encryption boards.
Will reprogramming the radios operating frequency affect the encryption boards in any way?
Is voice inversion encryption allowed on PMR 446? I'm not sure how it works but had concerns that the encryption may create unintelligible noise which might interfere with other peoples use of the public radio frequency.
radiotweester
Oregon
As long as you have the Encryption tab set to OFF or Key ON (and a key programmed it to turn it on/off) you shouldn't have any issue. I have no knowledge of PMR446 rules.
teufler
ST PETERS, MISSOURI
scramble takes no more frequency space then a normal signal. If you key up normally ade the frequency is occupied, you go to another frequency. PMR446 IS A eUROPEAN THING, CHECK THEIR REGS FOR SCAMBLE.Its similar to stateside FRS, and scramble is legal on FRS
topcatim
Does a one have any information on how the encryption board is configured? Is it true encryption with an encryption key that must be programmed into each radio to allow them to decrypt each other's transmissions or is the term encryption used more loosely with radios?
