Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Vertex Standard
Vertex Standard - Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 05-10-2017, 4:17 PM
Default VX2500E programming issue
Hello all,
I have a programming issue with a VX 2500E
I use the CE63 Ver 2.00 software with a homemade cable with max232 and lm7805.
1) radio ON
2) upload ( read dconfig from radio)
3) start ( a message from program say power of/on the radio )
4) power radio OFF
5) power radio ON
the config read don't start
I checked the cable
TX/RX to pin 8 with a 120 K hom resistor to +5V
GND to pin 5
VIN from pin 6 that give 9 Volt then regulated to 5 Volt with lm78m05
5V to pin 2 with a 3.3 K hom resistor
If I open the serial port with a teminal program I car read the keys that I type, the tx is connected to rx, and the signal arrive to pin 8 of the mic
When I power on the radio with channel up pressed I can read
053 1101
on the display.
Can somehone help me?
Alberto
Tags
vx2500e
