Good Evening everyone.
I have a Vx2500 programmed up for use. I have the radio programmed for the DB 9 connector as well to get audio from so the user can use that audio to feed a logging program on a PC. However when i monitor the audio from pin 2 of the DB 9 connector it does feed the audio to the logger but also feeds static between the transmissions as well. Am i correct in assuming that the audio from pin 2 of the DB 9 connector is picked off before the squelch circuit? or am i just missing something in the programming?
