Why can't i add more than 1 channel? (Vertex CE 39)
Priority-One
Anonymous participant
Banned
Bronx, NY
I finally was able to get my Vertex VX900 programmed with 1 channel. I went to add more channels and i have the ability to add 16 channels to 1 group, But i am unable to add anymore frequencies after channel 1.
I have went through every setting in CE 39. Is there something i am missing?
paulears
Lowestoft - UK
Can we see a screen shot of what you are trying to program that gets ignored or failed? Maybe we can see the issue, otherwise, we have no idea?
Priority-One
Banned
Bronx, NY
I can add the first channel (Channel 1) but I can not add anything further.
Danny37
New York City
Is this your first vertex radio? If so you need to activate the channels in the bank (if they're Greyed out) by scrolling down the channels list and hitting the space bar.
Also go to channel/group allocation and put 16 channels next the group name.
Tip: I see you're programming some PD channels for recieve only, go to the area of the transmit frequency and hit the space bar and you should get ---.----- that means the channel is recieve only and will give you an error when you try to xmit.
paulears
Lowestoft - UK
Is the problem that when you enter data into line two and below the radio doesn't accept it, or that you cannot enter the data into the CPS?
Priority-One
Banned
Bronx, NY
I figured it out. The firmware version of the CE 39 was 1.05 and the radio was 1.50. I upgraded the software and it works perfectly. Thanks for all the help
