Good evening all
I have a vx-p824 that is Ver H (380.100mhz - 449.900mhz) trying to change it to Ver D (450.100mhz - 519.000mhz) I am using CE76 and following the same steps as noted in another post for the CE59 I am able to get into developer mode ok able to make all changes under common/hardware changes from H to D make the edits ok then when I try to write to the radio it says "Hardware Missmatch" anyone had this issue? Can anyone explain what " Adjustment Recover" & "Hardware Data Initialize" are used for? thanks 73
