Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Vertex Standard
Vertex Standard - Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 06-21-2018, 9:30 PM
Default VXR-7000
Trying to program 2 VXR-7000's that I just found. I am using an old Windows 2000 laptop with the CE27 1.8 US firmware.
I am also using a USB not a Serial cable.
When I try to read or even write a code plug to the repeater it gives me an Error. I am on the correct COM port but not sure what else it could be.
Possibly the cable? Should I have ordered a Serial instead of a USB?
Help me please!!! Thank you
Old 06-23-2018, 11:32 AM
chief21's Avatar
When using the USB cable, are there special drivers that must be installed prior to using the software? Many of these older applications work best with a true serial cable, but I have no specific experience with the CE27 software.
- John
Old 06-23-2018, 11:37 AM
MTS2000des's Avatar
Why not use the modern supported Windows based CPS? If you're trying to use an old version under DOS, it's not going to play nice with a USB to RS232 dongle.
The latest CE-27 CPS is out there. Runs on modern PCs and WinXP/7/8/10 natively.
NO I will not help program your trunking radio. All opinions are exclusively those of the author and in no way reflect the position of his employer, contractors or other parties.
Old 06-23-2018, 11:39 AM
chief21's Avatar
More info - Just found these footnotes in the VX7000 manual and thought that the info might be helpful (especially the second note):
Important Note!
Do not run the CE27 programming software directly
from the original distribution diskette.
Copy the programming software to your
computer's hard disk, then run the software from
the hard disk only. Keep the original distribution
diskette in a safe place in case you need to
make another copy of it at a later date.
Before creating the programming data for your
VXR-7000 via the CE27 programming software,
upload the current factory hardware environment
data from the VXR-7000, using the [F5]
(ReadRom) command. Use this data profile to
create the programming data for this repeater.
Old 06-23-2018, 12:56 PM
You guys are awesome!!! So downloaded the updated Version 1.8 for windows and installed it on my Windows 10 desktop. and IT WORKS!!!! wow now I can stop stressing lol.
Old 06-23-2018, 1:02 PM
MTS2000des's Avatar
The Windows version of CE for VXR is so much easier to navigate than the ancient DOS based CE27. No headaches of trying to get ancient hardware to survive either.
FYI if you need wideband, just download the "international" version and it won't try to force narrowband on you (for ham applications of course).
Old 06-23-2018, 1:36 PM
Thank you for that info! I'll keep that in mind. It looks like there is an Ethernet cable plug on the rear of these 7000's. Is that used for connecting over internet or is that used as another port for programming?
Old 06-23-2018, 4:01 PM
MTS2000des's Avatar
The rear jack is for tone remote control (2 wire/4 wire) analog.
Old 06-23-2018, 4:02 PM
MTS2000des's Avatar
Link to fairly current service manual for the UHF VXR7K.
Old 06-23-2018, 5:32 PM
You need a FIF-12 Dongle and RJ45 pig tail to program it..unless you have a Ribless cable.
Old 06-24-2018, 12:33 AM
I was able to get the repeater programmed. Thanks everyone!! Next up are to try programming my EVX-R70's and VXD-R70's..
Old 06-24-2018, 8:13 PM
Same cable as a XPR Repeater
Old 07-17-2018, 9:03 PM
Default VXD-R70
delete!
