Yeah me
Does anyone know all the DMR in the state minus HAM stuff? I would like to find all the DMR for the whole state but I’m in Hampton Roads so it would be nice to listen. Thanks
FYI I track 22 FCC emission mode combinations via my VA directory for all 95 counties and 35 independent cities in MS EXCEL format. I do not track DC. I do weekly FCC updates currently at a file size of 71,437 as of July 07, 2018. However, there have been reported instances where an emission mode has been changed locally but not reflected as a modification to a licensed user and is undocumented.
For example, look at the problems Allen, N4JRI has had trying to id DMR users for one of tunnel crossings in Tidewater to the appropriate frequencies.
It can get messy. A few FCC licensees have modified their licenses for Analog and/or APCO P25 P1 and/or DMR and/or NXDN/NEXEDGE emissions. Unless monitored you won't know exactly which emission currently is being used.
DMR licenses typically are for both analog and MOTOTRBO emissions. In have heard a couple licensees use both but normally it is DMR. Other DMR licensees are for DMR only..no analog.
So although 100% accuracy always is the goal, with multiple emissions authorized for some, you cannot assume they always will be using DMR.
John
W4UVV
