Unitrunker>PSR-800>Netbook
radioscan
Radio Sensei
Southern Ohio
Attempting to run Unitrunker which I have not done in a long time.
I have set up the system I wish to decode on the PSR-800 from this page:
UniTrunker | PSR-310 | PSR-410 | PSR-500 | PSR-600 | PSR-700 | PSR-800 | PRO-107
Running this with the PSR-800 cable to an Acer Aspire One Netbook USB slot. My only input options from Unitrunker are 'Realtek HD Audio Input' and 'Microsoft Sound Mapper'. Neither setting is producing a signal into the program. Yes, the PC/IF out is enabled. Is there a setting I need to make in Device Manager? OS is Windows XP SP3.
Thanks,
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
IIRC, PC/IF Out on a PSR800 is via the headphone jack to a sound card input.
If you are doing it via USB, choose "Inline" as the receiver type in Unitrunker - then choose PSR800 from the subsequent list.
SCPD
QRT
Virginia
You can configure the 800 as a Signal receiver or an Inline receiver. To use the USB cable, create the receiver as an Inline model. The USB cable has the advantage of providing the current control channel frequency. The discriminator audio allows decoding additional protocols.
