  #41 (permalink)
Old 11-28-2014, 10:22 AM
RonnieUSA's Avatar
Try changing from 2.4Msps, to 1.024, and see if that clears it up any.
PSR-800 - BCT15X - FreeSCAN - NooElect R820T2+ SDR - NooElect R820T2 SDR - DSDPlus Fast Lane
  #42 (permalink)
Old 11-28-2014, 2:31 PM
Cool on Windows??
hello
sorry for the question but it is not practical with linux systems wanted to ask if it is possible to emulate the system under Windows 7 or otherwise if the porting is possible ..
Thanks but I admit my ignorance though I'm tempted to try it but I know that I will have problems hii
thank you
P.S. I understand that my request for a programmer and as a blasphemy ..
  #43 (permalink)
Old 11-28-2014, 2:43 PM
Originally Posted by mescalero View Post
hello
thank you
blasphemy is where someone does not care to read all avaliable information and asks questions
one of my posts has a link to a tutorial by rtl-sdr.com that shows how to install ubuntu and this software on a virtual machine under windows, look at that (not that i endorse this method, it won't give top performance, but you will get a taste of what this software does)
  #44 (permalink)
Old 11-28-2014, 2:56 PM
Originally Posted by yo4tnv View Post
IQ recordings (SDRsharp 16 and 32bit float, 2.4Msps) here [...]
i can't seem to read this file. i assume one channel has i and the other has q data, but i can't seem to read it. does someone have a specification how sdr# records these samples?
  #45 (permalink)
Old 11-28-2014, 4:58 PM
Smile
thanks for the reply
hi
I used the term blasphemy ironically not 'cause I had not read the tutorial ..
I said a real porting that could run on windows system on real not virtual machine that I realized the fact and indeed the performance is limited and does not do justice to your work
all qu
sorry but I speak bad English are Italian in Rome hiii
  #46 (permalink)
Old 11-29-2014, 3:30 AM
hansheesbeen's Avatar
Everything works fine now on linuxmint 17 except this error in gnuradio:
(python2.7:2955): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion 'GTK_IS_WIDGET (widget)' failed
  #47 (permalink)
Old 11-29-2014, 5:21 AM
i don't have this bug, but this is what i found on the internet:
this is a qt bug. if gnuradio-companion keeps running, then don't worry about it
if not, then run qtconfig and select gui style "cleanlooks"
  #48 (permalink)
Old 11-29-2014, 8:52 AM
Originally Posted by systron View Post
i hope that dsd+ will decode tetra soon...
any live tetra systems in the united states ?
Voice codec can be downloaded from ETSI and compiled for your own use, but there may be a problem if you want to distribute them in binary form. Any TETRA receiver software ready to use could put its author in serious legal trouble.
  #49 (permalink)
Old 11-29-2014, 11:54 AM
Hello , congratulations for the software , I'm trying to install telive on ubuntu 14.10 for try in the Italian system , someone managed to get it working on Ubuntu ? There are variations from the guidance presented on sdr - rtl ?
  #50 (permalink)
Old 11-29-2014, 2:40 PM
actually it would be interesting to know the status. the codec source has no licensing information, neither has the page that it can be downloaded from. ETSI has some IPR search form, which i wasn't able to use (probably too much stuff blocked on my browser, didn't really try much).
it would be interesting:
- if i can redistribute the source? (along with some install scripts that patch and compile it)
- if i can redistribute binaries? (if the project is non-commercial, and source is included) - probably not
any lawyers here?
btw mbelib also has a similar problem, and still people redistribute dsd and dsd+, and didn't have any problems (yet
  #51 (permalink)
Old 11-29-2014, 2:50 PM
any problems?
in the tutorial here: RTL-SDR Tutorial: Listening to TETRA Radio Channels - rtl-sdr.com they use ubuntu 14.04 32-bit. 14.10 will most probably work too.
if you're using a 64-bit system, they you will have to compile the codecs for 32-bits. there is a description in the documentation, this is for debian but probably will be the very similar for ubuntu. basically if you know what you're doing you shouldn't have any problems
  #52 (permalink)
Old 11-30-2014, 6:20 AM
Hello, I have run aground, running the command receiver startup cd ~ / osmo-tetra-sq5bpf / src ./receiver1 1, the terminal it says command not found. If regarding the installation of package gnu-radio, I find that the make command fails:
Proceed?y
Starting all functions at: sab 29 nov 2014, 16.21.34, CET
SUDO privileges are required
Do you have SUDO privileges?y
Continuing with script
Installing prerequisites.
====> THIS MAY TAKE QUITE SOME TIME <=====
Checking for package libfontconfig1-dev
Checking for package libxrender-dev
Checking for package libpulse-dev
Checking for package swig
Checking for package g++
Checking for package automake
Checking for package autoconf
Checking for package libtool
Checking for package python-dev
Checking for package libfftw3-dev
Checking for package libcppunit-dev
Checking for package libboost-all-dev
Checking for package libusb-dev
Checking for package libusb-1.0-0-dev
Checking for package fort77
Checking for package libsdl1.2-dev
Checking for package python-wxgtk2.8
Checking for package git-core
Checking for package libqt4-dev
Checking for package python-numpy
Checking for package ccache
Checking for package python-opengl
Checking for package libgsl0-dev
Checking for package python-cheetah
Checking for package python-lxml
Checking for package doxygen
Checking for package qt4-default
Checking for package qt4-dev-tools
Checking for package libqwt5-qt4-dev
Checking for package libqwtplot3d-qt4-dev
Checking for package pyqt4-dev-tools
Checking for package python-qwt5-qt4
Checking for package cmake
Checking for package wget
Checking for package libxi-dev
Checking for package python-docutils
Checking for package gtk2-engines-pixbuf
Checking for package r-base-dev
Checking for package python-tk
Checking for package liborc-0.4-0
Checking for package liborc-0.4-dev
Checking for package libasound2-dev
Checking for package python-gtk2
Done checking packages
Checking for library libusb ...Found library libusb
Checking for library libboost ...Found library libboost
Checking for library libcppunit ...Found library libcppunit
Checking for library libfftw ...Found library libfftw
Checking for library libgsl ...Found library libgsl
Done
This script will fetch Gnu Radio version 3.6.5.1 from the repositories, along with compatible
extras.
Is this OK?y
Fetching various packages (Gnu Radio, UHD, gr-osmosdr, gr-iqbal, etc)
via the Internet
=======> THIS MAY TAKE QUITE SOME TIME <=========
Fetching Gnu Radio via GIT...Done
Fetching UHD via GIT...Fetching rtl-sdr (rtl-sdr, gr-osmosdr, gr-iqbal, hackrf and bladeRF) via GIT
Branch gr3.6 set up to track remote branch gr3.6 from origin.
Switched to a new branch 'gr3.6'
Done
Starting function uhd_build at: sab 29 nov 2014, 16.30.54, CET
Building UHD...
=============> THIS WILL TAKE SOME TIME <=============
Done building/installing UHD
Done function uhd_build at: sab 29 nov 2014, 16.50.47, CET
Starting function firmware at: sab 29 nov 2014, 16.50.47, CET
Images destination: /usr/local/share/uhd/images
Downloading images from: http://files.ettus.com/binaries/imag...00-release.zip
Downloading images to: /tmp/tmpl_3cw3/uhd-images_003.008.000-release.zip
24787 kB / 24787 kB (100%)
Images successfully installed to: /usr/local/share/uhd/images
Done downloading firmware to /usr/local/share/uhd/images
Done function firmware at: sab 29 nov 2014, 16.52.27, CET
Starting function gnuradio_build at: sab 29 nov 2014, 16.52.27, CET
/usr/local/lib already in ld.so.conf.d
Doing ldconfig...
Building Gnu Radio...
=========> THIS WILL TAKE QUITE A WHILE <=============
...Doing cmake
...Cmaking
...Building
make failed
Exiting Gnu Radio build/install
From what little I understand of ubuntu, if the make and failed means that the receiver has not been created right? how can I do to fix?
thanks
  #53 (permalink)
Old 11-30-2014, 12:07 PM
[...]From what little I understand of ubuntu, if the make and failed means that the receiver has not been created right? how can I do to fix?
it's hard to tell, this script is used by a lot of people (not only for telive), and it usually works for them.
you can try to run verbose:
./build-gnuradio -o -v
and see what error you get.
  #54 (permalink)
Old 12-01-2014, 12:37 AM
System works great. Thank you!
  #55 (permalink)
Old 12-01-2014, 12:46 AM
Wink
Love to see a video of this working !
  #56 (permalink)
Old 12-01-2014, 3:12 AM
thanks. i hope you like it
i understand that you installed under linux mint? (64 or 32 bit?)
  #57 (permalink)
Old 12-01-2014, 3:13 AM
Yep installed under mint 17 32bit later i make al list with the changes for mint
  #58 (permalink)
Old 12-01-2014, 6:04 AM
there is a new telive version out, with slightly different colors for more redability, and a way to change verbosity (using v and V keys, less verbosity shows less logs in the status window), and showing text SDS directly in the status window (previously they were only in the logs)
also i have reports of a crash in sds decoding routines in tetra-rx (but only for some sds), this will be fixed once i nail it.
  #59 (permalink)
Old 12-01-2014, 9:58 AM
Hi I seem to have gotten somewhere using the tutorial provided... I can get the gnuradio radio going, but am I stuck on the part (Double click the variable labelled ppm and input your dongles particular PPM correction value) I have a NooElec R820T dongle! Do I not need drivers for this installed 1st? Have I missed something? All the software is installed with no errors... Running ubuntu 14.04 !
Sam
  #60 (permalink)
Old 12-01-2014, 12:30 PM
Installed everything as pair the tutorial... But when I run RTL_TEST I get his
sam@ubuntu:~$ rtl_test
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000008
Using device 0: Generic RTL2832U OEM
Kernel driver is active, or device is claimed by second instance of librtlsdr.
In the first case, please either detach or blacklist the kernel module
(dvb_usb_rtl28xxu), or enable automatic detaching at compile time.
usb_claim_interface error -6
Failed to open rtlsdr device #0.
Any ideas?
Tags
tetra decode
