  #961 (permalink)
Old 10-28-2015, 7:57 AM
Default Cubicsdr could be used as TETRA front end ?
Major trouble using Tetra decoder for years now is to adapt Front end to decoder .
Funcube or funcube pro + = QTHID
Rtl sdr = osmosdr-tetra_demod_fft.py
assuming cubicsdr has a IQ output , what demod could be use and how ?
Cubicsdr --> IQ --> tetra-demod.py ?
New interface soapy allow many SDR devices to run with cubicSDR
see :
https://github.com/pothosware/SoapySDR/wiki
https://github.com/cjcliffe/CubicSDR
  #962 (permalink)
Old 10-29-2015, 1:12 PM
Default New install script for Debian 8 and Ubuntu 14
New experimental install script. It should support Debian 8 , Ubuntu 14 (and distributions derived from it, such as Linux Mint 17.2), and maybe Ubuntu 15 (and derived distributions). This will also install gqrx, which is not needed for telive, but might be useful for other purposes.
To install:
- install your distribution of choice (but don't install any radio stuff)
- make sure you have internet access
- make sure that you have sudo rights for your normal user
- as this normal user (not root!) run:
Code:
wget https://raw.githubusercontent.com/sq5bpf/telive/master/scripts/install_telive.sh
# now here you should read the script, don't just blindly run scripts off the internet
chmod 755 install_telive.sh
./install_telive.sh
I haven't actually tested if it works, so feedback is very welcome.
  #963 (permalink)
Old 10-29-2015, 6:01 PM
I just tried the script on Debian 8.2 and it did not work. Here is what happened: (Screenshot should be attached)
  #964 (permalink)
Old 10-29-2015, 9:28 PM
fixed, try again
  #965 (permalink)
Old 10-29-2015, 11:53 PM
tested the first script, work fast and without problems.
VMWARE virtual machine
Debian GNU/Linux 8 (jessie) 64-bit
Installed telive and gnu-radio 3.7 with these script
  #966 (permalink)
Old 10-30-2015, 2:49 AM
great, thanks for the test (it confirms i fixed the bug repoorted by radiosification)
now if someone could test ubuntu 14, ubuntu 15 and linux mint, and also test if it actually works (sees the dongle, grc/python scripts don't give errors etc).
i'm sure it works under debian 8, but couldn't test under ubuntu. the ubuntu version uses gnuradio 3.7.5 packages from another repository.
  #967 (permalink)
Old 10-30-2015, 2:57 AM
i Can fire up Mint later today and test it out and maybe ubuntu if i get around to it
  #968 (permalink)
Old 10-30-2015, 7:10 AM
Working in Mint 17.2 cinnamon 64-bit thou getting "errors" in gnuradio
Warning: failed to XInitThreads()
at startup
and
(python:27119): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion 'GTK_IS_WIDGET (widget)' failed
9 times so for each channel im guessing
and did take some time to start up but running smoothly once i press "run"
P.S
gonna try the script on ubuntu 15 later tonight
  #969 (permalink)
Old 10-30-2015, 7:17 AM
at startup
and
good to hear it's running smoothly (don't worry about the gtk errors). if it works under Mint 17.2 , then it will most probably work under Ubuntu 14.x
now could anyone test in ubuntu 15?
  #970 (permalink)
Old 10-30-2015, 7:42 AM
Just tried on a fully updated fresh install of Xubuntu 15.10.
It fails to find the package gqrx, it is actually called gqrx-sdr in the ubuntu repos.
With this change the scripts runs, with some compile warnings.
So i moved on to the pdf and followed the first 1 channel simple receiver example but end up with missing blocks in gnuradio.
Those are osmosdr_source_c, gr_fractional_interpolator_xx and gr_file_sink.
Find attached the script's output as well as the compile and other errors generated.
Edit: My bad.. For gr3.7 i should really use the correct file 1ch_gr37..
Nevertheless, i cannot get any output. The receiver1 window produces no text, and nothing shows up in telive.
But the script as such seems to work fine with that minor adjustment.
  #971 (permalink)
Old 10-30-2015, 9:57 AM
thanks! fixed it
strange, it should work.
have you tried different networks or fine tuning the receive frequency?
  #972 (permalink)
Old 10-30-2015, 11:38 AM
i did some minor updates to the telive documentation (mainly describing the new install script)
as always it is located here:
Code:
https://github.com/sq5bpf/telive/raw/master/telive_doc.pdf
  #973 (permalink)
Old 10-30-2015, 12:01 PM
Actually, having added a waterfall plot and double checking with gqrx, i think something else is causing trouble. I have two very clear peaks at -30dB in gqrx, but they do not show up in gnuradio. For troubleshooting i entered the frequency of a local radio station which shows up looking just like a WFM transmission should. I'm quite at a loss here as to why the tetra transmissions won't show up.
  #974 (permalink)
Old 10-30-2015, 2:07 PM
if you haven't tried telive_1ch_simple_gr37.grc, then use that. no need to add a waterfall plot (there is a spectrum display, and the signals are always-on anyway). and you can click the spectrum to tune the receiver.
did you look at messages in gnuradio-companion? maybe you don't have access to the dongle (no access rights, maybe you need to blacklist the dvb-t driver etc). in this case the osomocom source will produce random data to avoid a gnuradio bug.
  #975 (permalink)
Old 10-30-2015, 3:53 PM
Got it working with telive_1ch_simple_gr37.grc. Thanks, mate.
  #976 (permalink)
Old 10-30-2015, 7:20 PM
Hello again. Remember me? I helped you with the bug of the locations (so much time ago).
Again: sorry for my English.
Actually I'veo got a dedicated pc with Ubuntu 14.04 running telive, connected via phisical cable to my main pc for sending the audio of telive to zello and my phone.
Got Apache working to see GPS locations in Earth in my main pc.
I'd like to make a suggestion.
I hope you understand me.
It would be nice if I could feed data trough http about the ssi that's transmitting, the UI (usage identifier) and all of that data. Just a suggestion.
Also, does anyone know how can I send my telive audio trough Zello to my phone, directly from my TETRA-dedicated pc?
A salute to everyone, and a big big hug to my friend sq5bpf who gave me the hablity to listen TETRA networks hahah.
It would be nice, too, that we can se who is tx'ing and who is rx'ing. Just giving ideas.
Bye.
  #977 (permalink)
Old 10-31-2015, 12:18 PM
fixed, try again
Thanks. I can confirm it works well now.
  #978 (permalink)
Old 11-01-2015, 9:59 AM
Default Great Install Script !!
And I can confirm that I also have it up and running. But one thing I have to install before it was working was sudo apt-get install python-numpy.
This was on a fresh Linux Mint 17.2 Mate. 64 Bit LTS Desktop Version.
Also i do not understand haw Codec is installed. There is a install script. Is it for compiling and installing the codec, ?
I just manuel copy the alredy compiled codec I have to /home/[user]/tetra/telive/bin/
Thank for creating this install script. It is just so much easyer to install now.... !!!!!
  #979 (permalink)
Old 11-01-2015, 10:20 AM
this is strange because gnuradio recomends python-scipy, which depends on python-numpy. maybe you turned off the installation of recommended packages? (which is on by default)
there is a separate github repository with a script that will download the reference codec from the etsi.org website, patch, compile and install it. this is separate on purpose, because others might want to use it in their projects.
look at this repository (especially the install.sh script):
Code:
https://github.com/sq5bpf/install-tetra-codec
edit: the fact that python-numpy is not a dependency is actually a bug in the ubuntu gnuradio package:
Code:
https://bugs.launchpad.net/ubuntu/+source/gnuradio/+bug/1471351
  #980 (permalink)
Old 11-01-2015, 10:32 AM
Yeah i find this wierd as well Mate and cinnamon should not have any differences in packages concerning python as my script run on mint 17 didnt turn out any errors during install and that was cinnamon
Tags
tetra decode
