  #1201 (permalink)
Old 03-04-2016, 11:58 AM
Originally Posted by FR3500 View Post
Ok thank you
What would result?
As i said all files are recorded and present,( i'm almost certain)
the issue may come from enconding by tetrad
i'm not so sure. looks like more of a permissions problem
tetrad works like this:
1. find all files in /tetra/in that are older than 2 minutes
for each file: {
2. move the file to /tetra/out/YYYYMMDD/FILENAME.out
3. uncompress acelp, compress this into ogg
4. remove all files except the ogg file
5. wait 1 minute
this mechanism works without any error checking (bad, i know, but this was only a quick hack, left it because it's very reliable anyway, i can change it if you want).
before looking at problems in tetrad i would look into the system:
- is this a standard installation? (debian 8 and everything installed via install_telive.sh), or is there something non-standard about it?
- maybe you're running this as root? (deadly unix sin, you should run the software as a normal user and not abuse root, this can also cause permissions problems later)
- maybe your filesystem ran out of free space (or free inodes) at some point?
- maybe something else was done with the script? (killed because of low memory etc)
if it is none of these, then do this experiment: don't run tetrad, let some recordings accumulate, and make a copy of /tetra/in. after this launch tetrad. if you find an .out file that will not be processed by it, then please send it to me (maybe it causes a segfault of the acelp decoder)
  #1202 (permalink)
Old 03-04-2016, 1:11 PM
OK thanks for your time;
Actually i did exactly that, i let run the program for 1 hour, it recorded 62 files;
then i ran tetrad to endode to ogg; about 30" total encoding time:
the result was only 1 file missing (61)
I'm on ubuntu 14, will try soon Debian;
just wondering why tetrad runs perfectly, but very few errors ...
  #1203 (permalink)
Old 03-04-2016, 1:19 PM
I tried few minutes ago, 182 files encoded, no missing
  #1204 (permalink)
Old 03-04-2016, 2:47 PM
do you have the out file that was missed by tetrad? (if so, please send it to me)
i have no idea too. it should either work 100% or 0%. the only reason might be a segfault in cdecoder or sdecoder (i assume that sox and oggenc work correctly), maybe you could look at your kernel logs (/var/log/kern.log and other files in /var/log), it should be logged there.
  #1205 (permalink)
Old 03-04-2016, 5:09 PM
i have no idea too.
If two files are created within that minute for the same participants. Wouldn't that result in the filename being the same thus being overwritten?
  #1206 (permalink)
Old 03-05-2016, 2:08 AM
the files are named traffic_IDX.out (with IDX=3-63, this are the traffic usage markers), which are later renamed to a file which has also has the IDX in the name. even if you had 2 files with the same SSIs in the filename (unlikely but possible), this would differ by the IDX, (this is without having a deeper look at the code, i may be wrong)
  #1207 (permalink)
Old 03-05-2016, 9:02 AM
Default Telive install problem
git clone https://github.com/sq5bpf/telive ---- OK
cd telive ---- OK
make --- OK
sudo mkdir /tetra --- NOT OK
NOT OK, Ubuntu says folder or file already exist. But i don't see it in my files, the tetra folder not exist
sudo chown mygroup /tetra ----- OK
chmod 755 install.sh --- OK
./install.sh ---- NOT OK
It says :
/tetra/in already exist
/tetra/out already exist
/tetra/log already exist
/tetra tmp already exist
/tetra/bin already exist
But no trace of theses files ! They don't exist.
Help
  #1208 (permalink)
Old 03-06-2016, 4:44 AM
atariman, did you try using the automatic install script?
ls -al /tetra returns nothing?
  #1209 (permalink)
Old 03-06-2016, 5:10 AM
Now it's ok for the folders. Because they were in the first root folder and not my personal folder. But i have and other problem. I am on a tetra signal and it's ok with osmocom tetra. The trame is decoding in the window ( burst etc....) but nothing with the /receiver1 under telive. The files fifo and fifo are ok. The size of fifo1 evolute, ok but there is nothing text in receiver1. No decoding signal. My frequency is ok on tetra signal and fine. All installation ok. What is the problem ? I am testing with rtl sdr key with grc_simple et a funcube with grc_fcd the problem is same: nothing in receiver1
  #1210 (permalink)
Old 03-06-2016, 3:05 PM
see if these are pipes:
ls -al /tmp/fifo*
what parameter did you pass to receiver1? this determines the pipe name (if the parameter is 1, then it uses /tmp/fifo1)
  #1211 (permalink)
Old 03-07-2016, 1:39 AM
Thx for answer.
If i type : ls -al /tmp/fifo*
prw-rw-r-- 1 jm62 jm62 0 mars 7 08:35 /tmp/fifo
-rw-rw-r-- 1 jm62 jm62 499712 mars 7 08:38 /tmp/fifo1
FIFO exist when i launch receiver1
FIFO1 exist when i launch GRC gnu radio
I think i don't send parameters to /receiver1. I'm just type ./receiver1 and execute. I am testing without the -a parameter and it's the same.
  #1212 (permalink)
Old 03-07-2016, 2:45 AM
Default Good
It's good now !!
I need to do ./receiver 1
I forgot the 1
Thank you
  #1213 (permalink)
Old 03-07-2016, 3:32 AM
I am not lucky . All is ok but i don't have audio files in /tetra/in ou out folder. The codecs are ok, i hear "HELLO TETRA" with the filetest.acelp but no files in OUT and IN folders. In the Xterm i do SHIFT+R for recording, but there"s nothing append.
  #1214 (permalink)
Old 03-07-2016, 5:13 AM
do you have any unencrypted voice traffic on your network?
if there is voice traffic and you have record:1 on the screen, and there are no permissions problems (telive can write to /tetra/in), then it should work. you can disable mutessi and see if this helps (if there is no SSI information about the voice traffic)
  #1215 (permalink)
Old 03-08-2016, 2:47 AM
There is Voice traffic indication ( and i know the origin of the signal, there is voices )
And no encryption ( ENCRYPTION : 0 )
I think all permissions are ok ( folder tetra is on access files parameter and the subfolders IN ... OUT )
But how to disable MUTESSI ?
  #1216 (permalink)
Old 03-08-2016, 3:09 AM
EDIT : I find mutessi ( m , under ./rxx window telive ) but the problem is same : I hear no voice and no filtes generated in IN folder.
Few lines of the log file
20160308 10:04:30 FUNC:SDS [01001111011001100010010110011010101100001000000100 00010000000000011111000000001000000110000000000000 00011110000000000000000100001000000000000000000000 0000000000000]
20160308 10:04:30 FUNC:SDSDEC [CPTI:1 CalledSSI:200409 CallingSSI:9999978 CallingEXT:0 UserData4: len:56 protoid:82(Text Messaging) SDS-TL:[ MsgType:SDS-TRANSFER MSG_REF:62 TO_GROUP:0] coding_scheme:01 DATA:[\x03\x00\x00\xF0]] RX:1
20160308 10:04:30 FUNC-SDS DATA SSI:00200409 IDX:000 IDT:1 ENCR:0 RX:1
20160308 10:04:32 FUNC-STATUS SSI:00200002 IDX:000 IDT:1 ENCR:0 RX:1
20160308 10:04:32 FUNC-STATUS SSI:00202016 IDX:000 IDT:1 ENCR:0 RX:1
  #1217 (permalink)
Old 03-08-2016, 4:22 AM
Now it's ok : I put all write and acces permissions to folder TETRA / IN / OUT and now i hear the voices and the files traffic are or in the IN folder. Thanks for your help.
  #1218 (permalink)
Old 03-08-2016, 5:09 AM
that's strange, because you shouldn't have to do this, the install script takes care of all permissions
launch tetrad to recompress them into ogg files for later listening (see the docs)
  #1219 (permalink)
Old 03-09-2016, 4:21 AM
i've commited a small change to the install_telive.sh script, which should work around recent errors when instaling on Ubuntu 14 and distros derived from it (Linux Mint 17.3 and others)
the problem was that the software needs modern gnuradio, and under ubuntu 14 this is provided by external repositories, which can stop working (because their authors lost interest etc). this fix changes repos.
there is also the option to skip codec install (see the script comments).
if anyone tries this, i would be grateful for info if it does/doesn't work and bugreports
of course the preferred distribution is still debian 8, the rest is supported on an ad-hoc basis
  #1220 (permalink)
Old 03-09-2016, 3:06 PM
martufello's Avatar
Ubunt14.04.2 with preinstalled gnuradio 3.7.7.1 live iso USB working well
Ubunt14.04.3 with preinstalled gnuradio 3.7.9.1 live iso USB not ok
Gnuradio is starting and I can see tetra signals but I have following messages:
<<< Welcome to GNU Radio Companion 3.7.9.1 >>>
Preferences file: /home/ubuntu/.gnuradio/grc.conf
Block paths:
/usr/local/share/gnuradio/grc/blocks
/home/ubuntu/.grc_gnuradio
Loading: "/home/ubuntu/tetra/telive/gnuradio-companion/telive_1ch_simple_gr37_udp.grc"
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.009.002-13-g97d338d2
RuntimeError('fsm::fsm(const char *name): file open error\n',)
>>> Done
Showing: "/home/ubuntu/tetra/telive/gnuradio-companion/telive_1ch_simple_gr37_udp.grc"
Loading: "/home/ubuntu/tetra/telive/gnuradio-companion/telive_1ch_simple_gr37.grc"
>>> Done
Showing: "/home/ubuntu/tetra/telive/gnuradio-companion/telive_1ch_simple_gr37.grc"
Generating: '/home/ubuntu/tetra/telive/gnuradio-companion/top_block.py'
Executing: /usr/bin/python2 -u /home/ubuntu/tetra/telive/gnuradio-companion/top_block.py
Using Volk machine: avx2_64_mmx
gr-osmosdr v0.1.4-67-gac15e789 (0.1.5git) gnuradio 3.7.9.1
built-in source types: file fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy redpitaya
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Detached kernel driver
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Exact sample rate is: 2000000.052982 Hz
gr::log :INFO: controlport - Apache Thrift: -h ubuntu -p 9090
Receiver1 not logging and after stopping I have following message:
ubuntu@ubuntu:~$ cd ~/tetra/osmo-tetra-sq5bpf/src
ubuntu@ubuntu:~/tetra/osmo-tetra-sq5bpf/src$ ./receiver1
^C/tmp/fifo: Interrupted system call
File "demod/python-3.7/simdemod2.py", line 78, in <module>
tb = top_block()
Tags
tetra decode
