  #121 (permalink)
Old 12-05-2014, 9:26 AM
are now to work, control as soon as I can to check. thank you. still gqrx, do not know well Linux, then chroot and for me unknown, someone has developed for example, even just sdrsharp or other side of telive without compromising telive? and if you how? hraxie yet.
  #122 (permalink)
Old 12-05-2014, 11:58 AM
Smile
Greetings to me too need help (PM)
Maurizio
  #123 (permalink)
Old 12-05-2014, 2:53 PM
Default Thanks
Great software up and running now..thanks
  #124 (permalink)
Old 12-05-2014, 4:04 PM
I'm stuck on step 2 - installing gnu radio 3.6. The script ends with the following error
Fetching various packages (Gnu Radio, UHD, gr-osmosdr, gr-iqbal, etc)
via the Internet
=======> THIS MAY TAKE QUITE SOME TIME <=========
Fetching Gnu Radio via GIT...Done
Fetching UHD via GIT...GIT checkout of UHD FAILED
If you have found this script useful and time-saving, consider a
donation to help me keep build-gnuradio, simple_ra, SIDsuite,
meteor_detector, simple_fm_rcv, and multimode maintained and up to date.
A simple paypal transfer to mleech@ripnet.com is all you need to do.
Send success/fail info to sbrac.org?y
Any idea? Debian 7.7 here.
  #125 (permalink)
Old 12-05-2014, 5:18 PM
I actually occurred Air encryption 1 , then Tetrapol guess. This is not possible to decode or mistaken .
  #126 (permalink)
Old 12-05-2014, 5:20 PM
hansheesbeen's Avatar
Guess 380/390 MHz. Indeed encrypted. Same here. Normal tetra with tea2 encryption...
  #127 (permalink)
Old 12-06-2014, 2:18 AM
probably something wrong with accessing the repository on github (maybe a firewall blocking it?). please check if this works now.
look at the build-gnuradio script - it is a very straightforward shell script, so should be easy to understand and debug. and also search the internet for answers, the build-gnuradio script from SBRAC is used by thousands of people around the world, and you should be able to find a solution to your problem.
  #128 (permalink)
Old 12-06-2014, 2:23 AM
Unfortunately none of those 5 or 6 signals here on my QTH are unencrypted. All of them carry the same MCC/MNC. I will leave it working for a while in a work day, to see if i catch something in my fishnet.. I am thinking of a sh script to launch all tools at once in the proper order.
Also thinking of an supplementary block in GRC to FM demod the signal and hear the buzz, for audible bias based on signal intensity.
  #129 (permalink)
Old 12-06-2014, 2:47 AM
enable recording (and mutessi, although that can skip some traffic) , and leave it on for at least a week. if you have enough cpu, then you can decode all channels simultaneusly. i've recently commited 3, 5 and 6 channel receivers to the telive github repository, so you can use only one dongle for all channels if they fit within the dongle bandwidth
please don't publish
this will make people try to use the software without reading the documentation first, and as a result ask stupid questions later (look at questions in dsd topics on this forum for a quick sample)
this is easy, but won't get you any advantage (and will result in more cpu use), the spectrum display is much better for this.
  #130 (permalink)
Old 12-06-2014, 2:56 AM
I saw that
Of course
I have enought cpu on A6/quad APU, but i will move the setup on my tiny home server (Mini-ITX Atom 330/64bit capable) to leave it rolling for long time/less power consumption. Also i have two dongles (bought second one for unitrunker sport) and i will try to put them both to work.
  #131 (permalink)
Old 12-06-2014, 3:05 AM
in the ets-codecs package, is there amr-codec needed or only c-code?
My ./rxx tetra monitor is pretty empty, from time to time showing PLAY on red and OK on white. Is there a legend for that?
I know, I know.. I`ll read the docs..
  #132 (permalink)
Old 12-06-2014, 3:44 AM
I do receive garbled sound from time to time. Is there a codec problem? please help
  #133 (permalink)
Old 12-06-2014, 12:22 PM
Did you get the codec problem solving telive?
  #134 (permalink)
Old 12-06-2014, 12:51 PM
if the files with garbled audio are all called traffic_xxx_yyy_0_0_0.ogg, then enable mutessi
  #135 (permalink)
Old 12-06-2014, 1:54 PM
c-code only
http://www.tandcca.com/about/page/12029
"Adaptive Multiple Rate (AMR) Voice Codec
The AMR codec, operating in the 4.75 kbits/s only mode, has been chosen for possible future applications in TETRA. However, completion of the Air Interface Standard to accommodate the AMR codec is suspended in TC TETRA until sufficient market need is identified"
OK - i got some recent traffic on this usage identifier
PLAY - i am playing this audio now (this will show sometimes even with encrypted audio unfortunately)
for now this is not in the docs, will fix that in the future
EDIT: actually this was in the docs so no fix necssesary
  #136 (permalink)
Old 12-06-2014, 1:59 PM
if you see any output from tetra-rx (receiver1 script etc..), then this is tetra.
tetrapol is something completly different, the only similarity is the first 5 letters of the name
  #137 (permalink)
Old 12-06-2014, 3:54 PM
On some frequencies feel perfect audio, on the other, where the air crypto 1 audio is inconprensibile. This leads me to think that it is Tetrapol or that other kind of crypto may be used in combination with tetra?
  #138 (permalink)
Old 12-06-2014, 4:02 PM
enable mutessi. also it may be that these networks with encryption turned on carry only encrypted traffic, and you will never hear anything on them
i'm happy to hear that you have perfect audio on unencrypted ones.
this is not tetrapol. tetrapol is to tetra like DMR to NXDN (not much in common). this is most probably encrypted tetra, some services additionally use end-to-end encryption
  #139 (permalink)
Old 12-06-2014, 6:25 PM
Hi. Following the tutorial in RTL-SDR, using Ubuntu 14.04 LTS 32bit. USB Nooelec receiver. Installing GNU radio 3.6 take a lot hours maybe low speed internet. Now try to run software and this error
user@ubuntu:~/osmo-tetra-sq5bpf/src$ ./receiver1 1
File "demod/python/simdemod2.py", line 18, in <module>
import osmosdr
ImportError: No module named osmosdr
Any idea to fix it?
  #140 (permalink)
Old 12-07-2014, 2:13 AM
After trying to install gnuradio in Kali 32 bit and Lubuntu, I gave Debian 7.7 a try. It took really a while, but it works with my rtlsdr and delivers clear audio. Tuning in the top block gui isn''t as easy as in the original osmotetra, but it works and that's the main point for me.
Thanks for this great work!
Tags
tetra decode
