  #1541 (permalink)
Old 10-04-2017, 2:59 PM
Originally Posted by grahampaull View Post
No, I would be 99.99% sure this won't run on an RPI. Tetra is pretty resource hungry.
actually one channel runs fine on a rpi 3
you could probably do two, and maybe stretch this to three with some audio hickups
  #1542 (permalink)
Old 10-05-2017, 5:11 PM
Originally Posted by sq5bpf View Post
now i could make a modification to have the status messages appear also in the telive status window, but i'm not sure if it might produce to much output. could people with busy tetra networks test the patch and see what is the maximum amount of status messages in one minute?
[/url]
Thanks, I've tested on a quite busy network, but it's not too much status traffic. Maybe something every 5-10 minutes on the site I checked.
All status messages so far has been 65024. Also in all cases so far the SSI has been the mobile station id, and the SSI2 a GSSI (group). This was the same on two completely independent systems.
  #1543 (permalink)
Old 10-06-2017, 2:01 AM
@oz1jua, can you share your program ? It look very handy with multiple sites en receivers
  #1544 (permalink)
Old 10-07-2017, 4:06 AM
I have already done this. But here it is: https://github.com/oz1jua/StrTelive
  #1545 (permalink)
Old 10-07-2017, 4:18 AM
A have also testet on 2 sites on same network and on one site it only give same result 5-10 minutes.
The other site it give 0.
It still could be nice to know what is ISSI and GSSI. I know it is not simple to implement from SSI.
I have try to se what different in the hex dump off SSI but cant se the differen in SSI.
So that have to be done in the osmo core code. I have a system I know what is the GSSI and ISSI.
And that system we can use to check against if this is any help.
  #1546 (permalink)
Old 10-23-2017, 5:57 PM
Question
Hi,
Thanks for making this software!
I'd like to ask a question about the time between a call is made and it gets recorded as OGG.
Taking a look inside the "tetrad" script, I can see there's a sixty second sleep at the end, following a find for the files modified more than two minutes ago. So, would lowering the sleep make the files to get encoded sooner, or is it not enough?
Thanks in advance
  #1547 (permalink)
Old 10-29-2017, 11:37 PM
CqDx's Avatar
Hi all
I have been trying to set up two RTLSDR receivers to monitor two different network . However both rtlsdr reports the same device ID when I use the lsusb command. Is there a way to “force” one instance of gnuradio to use a particular rtlsdr receiver?
  #1548 (permalink)
Old 11-04-2017, 11:22 PM
Default KML Formatting
Hello!
I don't know if you remember me. I helped you to fix a bug with the locations. So much time ago.
Now I need a little modification, but I don't know where or how to do it. I need that my KML files generated by TELIVE use the SSI Alias instead of the SSI for the name of the marks.
How can I do it?
I leave a photo so you understand better what I need to do.
73
  #1549 (permalink)
Old 12-28-2017, 11:01 AM
SO good to see you are still around sq5bpf!
Can confirm I have been using telive successfully on clean install of Debian9 64bit and using the telive auto install and all working fine.
Running on desktop with 4gb RAM and Intel® Core™ i3-2120 CPU @ 3.30GHz × 4
Have just been running 1channel.
Just have these questions:
1) How are you guys using multiple SDR dongles (receivers)?
2) If I use more than one channel (3/4/6/etc) what should I be setting the other frequencies to?
I sometimes get a squeeky garbled sound when running more than one channel. I also get it sometimes when running 1 channel, but suspect that is due to some comms being encrypted although mutessi=1
Here is an idea of what I am getting(attached):
Any ideas?
  #1550 (permalink)
Old 01-06-2018, 4:56 PM
Default Front end
Some years ago , I asked the same question .
Recent sdr front end software like CubicSDR or Gqrx has IQ ready output . Gqrx has I/Q and UDP output
all major SDR's are compatible with this front end . It is less CPU consuming than standard GRC gnuradio
supported by telive .
I tried some tests with both software and I didn't succeed .
Some can test based on what is running very well :
Funcube pro + (using QTHID) --> telive
  #1551 (permalink)
Old 01-25-2018, 8:09 PM
Default StrTelive
Added version 0.20 StrTelive. New version can also start Telive with FIFO files. https://github.com/oz1jua/StrTelive
  #1552 (permalink)
Old 01-27-2018, 6:09 AM
Well Windows solution arrive with Sdrsharp and TETRA plug In . Nice job . It is the answer of my 3 years old question !!
  #1553 (permalink)
Old 01-30-2018, 10:28 PM
I have tried the plugin of Tetra decoder for SDR# but there are some people have the same problem wioth me. We can't see the decoder show up in SDR# and there's the same crash message when close SDR#. Please refer this:
https://www.rtl-sdr.com/tetra-decode...#comment-89305
Someone could help us to check that? Thank you...
  #1554 (permalink)
Old 02-03-2018, 5:25 AM
Wink try this!
You have to copy both ''SDRSharp.Tetra.dll'' and ''libtetradec.dll'' in your SDR# directory. Set in WFM and 25k bandwidth. Disable filter audio and set the sample rate to 2.4 MSPS max.
Set the right gain and click demodulator
  #1555 (permalink)
Old 02-03-2018, 11:19 AM
Work 100% only WIN-10 work as good as in Linux, Not working fully in others WIN
With RTL you need at least -40dBm SSI to get clear audio, lower give to many noise cause to many bit errors and decoder will not work proper.
Thanks for the help C
  #1556 (permalink)
Old 02-03-2018, 2:40 PM
There's no forward error correction so there must be a very clean signal without noise to be able to decode properly.
/Ubbe
  #1557 (permalink)
Old 02-03-2018, 2:48 PM
"65024 - reply when the called device acknowledges receiving a status message"
https://forums.radioreference.com/vo...coding-77.html
/Ubbe
  #1558 (permalink)
Old 02-03-2018, 8:08 PM
Originally Posted by Ubbe View Post
There's no forward error correction so there must be a very clean signal without noise to be able to decode properly. /Ubbe
Thats what i say
  #1559 (permalink)
Old 02-10-2018, 5:48 PM
Default only 1 channel
If this windows plugin only decodes 1 channel 4 TMDA slots then it is not as good as Telive on Linux.
Telive on linux can decode up to 12-16 channel with a powerful PC.
  #1560 (permalink)
Old 02-10-2018, 5:52 PM
They are working on it. According their forums they are wanting to bring the whole TELive across to Windows.
The developer is relying on people sending him IQ recordings as far as I know so he is limited as he doesn't have access to any big networks.
Sent from my SM-G950F using Tapatalk
Tags
tetra decode
