  #401 (permalink)
Old 06-11-2018, 8:32 PM
Have a look in "sdrtrunk_app.log" in "SDRTrunk\logs" to see if JMBE has loaded.
When you have P25 channel started there should be an entry in the log:
Code:
20180612 115134.917 [AWT-EventQueue-0] INFO  i.g.d.m.d.p.a.P25AudioModule - JMBE audio conversion library [JMBE Audio Conversion Library v0.3.3] successfully loaded - P25 audio will be available  [20MB/29MB 68%]
If not loaded, then file is not where it should be or is bad.
If is loaded, then issue is else where.
I don't use P25 so I can't help beyond that.
  #402 (permalink)
Old 06-11-2018, 9:12 PM
AB9NN's Avatar
THANKS for the informative response. I found the log - or at least the one from last night. I have concerns. Here are the log contents pertinent to our discussion:
20180611 220822.780 [sdrtrunk pool-1-thread-4] INFO i.g.d.m.d.p.a.P25AudioModule - JMBE audio conversion library [JMBE Audio Conversion Library v0.3.3] successfully loaded - P25 audio will be available [147MB/256MB 57%]
20180611 220822.792 [sdrtrunk pool-1-thread-4] INFO i.g.d.source.tuner.TunerModel - Unable to source channel [853875000] from preferred tuner [RTL2832 SDR/R820T 00000001] - searching for another tuner [148MB/256MB 57%]
20180611 222336.433 [AWT-EventQueue-0] ERROR i.g.d.s.t.r.r.R820TTunerEditor - R820T Tuner Controller - couldn't apply sample rate setting [2.400 MHz] [469MB/1GB 31%]
org.usb4java.LibUsbException: USB error 9: error writing byte buffer: Pipe error
In particular:
I think that the radio is not being fully accessed since the lower right panel on the Tuner tab is grayed out even though a radio shows in the rest of the panel.
Another concern. What relative size is the JMBE Library file? Mine is around 69 KB. Seems small. Makes me wonder if it's really all there... smile.
  #403 (permalink)
Old 06-11-2018, 9:47 PM
How many dongles you using?
Outside of SDRTrunk do the dongles work? (like in SDR#).
You may need to re-run Zadig.
Is your PC CPU OK. When pooling dongles like SDRTrunk does it can be taxing on the system.
Poor CPU performance can affect USB throughput.
A tool called RTLTool can test this and check available sample rates.
RTLTool
69Kb sounds right - It's only the decoder part.
  #404 (permalink)
Old 06-12-2018, 5:54 AM
AB9NN's Avatar
I ran the test - and it produced nothing... I tried both versions of the test software. It found the dongles and allowed me to select one. I tested both. I selected no bits, then 1 - 7 sequentially, then all except zero. Clicking the test button produced no change in the tool. I think it reads the name but can't fully connect to it just like SDRTunk. The dongles work with other softwares like SDR# but have issues when changing frequencies.
I am using two dongles. They had worked surprisingly well for a good amount of time both with SDRTrunk and with other softwares. Both dongles being used by SDRTrunk and in a configuration where one dongle used SDRTrunk (or was used by it) and the other running other software (supplying signal to that other software). That was on an old but 3 year old then new Windows 10 PC with memory maxed out. Since that time I acquired a new PC. I believe it to be a good VR machine. I will test however. I would be surprised if that were the issue. Especially since they worked well until a Windows 10 update.
I will continue to work with Zadig but have done that. I will continue to work with it... PC CPU should be fine as it is new. Also, they worked on old PC until the driver install issues.
  #405 (permalink)
Old 06-12-2018, 7:51 AM
The 'RTLTool' "Dongle Test" when run, you should see data transferred with no BYTEs lost.
If BYTEs are lost then stop and continue OK then usually dongle is no good at that sample rate.
If BYTEs are continually lost with the selected sample rate (ie. 2.4) then a problem exists. Usually CPU and or USB throughput.
If no data is transferred then there maybe be an issue with hardware or drivers.
Not sure what "Set GPIO bits" is for. (for what dongle that is)
Other than re-installing drivers and a power cycling PC, you could try connecting dongles via powered USB hub. A recent Win10 update caused people issues. Zadig was the answer in there case.
This issue seems less like SDRTrunk problem now. Hope you can get it backup and running.
  #406 (permalink)
Old 06-12-2018, 8:17 AM
AB9NN's Avatar
I ran RTLTOOL and it did absolutely nothing. Played with it for some time, chose the dongle, selected pins, pressed test, etc.. Bits were 0 0 0 in the top right panel. So...
When the dongle is running with SDRTrunk on my old PC it tuns fine. The Tuners tab, after the tuner is selected, is populated with data and controls. On the new machine - that doesn't really happen. Therefore I suspect it is not hardware related since it does two different things on two different machines.
I have power cycled the new PC many times and changed ports with same results every time. I do have a powered USB hum and also tried directly plugged into the PC.
The ports on the new PC are USB 3 but they worked until the Windows 10 update and a Zadig re-install. Then things got funky.
Thanks for the smart, logical steps to try!
  #407 (permalink)
Old Yesterday, 5:36 AM
AB9NN's Avatar
Default JMBE Build Fails - 3 incompatible and 1 stopped Daemons could not be reused,
Denny - I am following these steps: https://github.com/DSheirer/jmbe and my Java passes the tests.
When I CD to the correct folder and run the bat file it produces a jar file but it will not run.
The build process throws the following erroors:
C:\Users\jkres\Downloads\jmbe-0.3.3b\jmbe-0.3.3b>gradlew.bat build
Starting a Gradle Daemon, 3 incompatible and 1 stopped Daemons could not be reused, use --status for details
> Configure project :
Your finished JMBE library is here: C:\Users\jkres\Downloads\jmbe-0.3.3b\jmbe-0.3.3b\build/libs
BUILD SUCCESSFUL in 8s
7 actionable tasks: 2 executed, 5 up-to-date
C:\Users\jkres\Downloads\jmbe-0.3.3b\jmbe-0.3.3b>gradlew.bat --status
PID STATUS INFO
15764 IDLE 4.4
17580 STOPPED (by user or operating system)
15424 STOPPED (by user or operating system)
8052 STOPPED (by user or operating system)
Only Daemons for the current Gradle version are displayed. See https://docs.gradle.org/4.4/userguid...tml#sec:status
Not sure how to proceed. Thanks.
  #408 (permalink)
Old Today, 4:44 AM
You've built the JMBE library, so all you have to do now is copy that library file to the same folder as the sdrtrunk application and then launch the application.
Download the sdrtrunk release from the releases page, if you haven't already:
https://github.com/DSheirer/sdrtrunk/releases
Copy the JMBE library file that you just created to the same folder where you've downloaded the sdrtrunk application. The JMBE library file should be named: jmbe-0.3.3b.jar
Double-click the sdrtrunk application file, or in a console/terminal window change to the download folder and type:
java -jar (applicationfilename)
Denny
  #409 (permalink)
Old Today, 6:05 AM
AB9NN's Avatar
Default R820T Tuner Controller - couldn't apply the sample rate setting (2,400 MHz) USB error
Denny - thanks. The application throws the error:
R820T Tuner Controller - couldn't apply the sample rate setting (2,400 MHz) USB error 9: error writting byte buffer:Pipe error
The application (SDRTrunk) starts and loads channels. The bottom right box of the Tuners tab, after I have clicked on a tuner, is grayed out except for "Please select a tuner". It will play no audio but I can see the signals on the waterfall and all other tabs seem normal.
The application files are direct copies from my old PC. The same RTLSDR dongle works fine with the same application (version, etc) on the old PC. I have examined all the tabs and don't see an adjustment I need to make are change. Here is the output of the command you gave me: I do see in the output dump the following: ".usb4java.LibUsbException". Some Java issue? I am running Java 10 and have it configured in Windows 10 the same, including folder locations, names, contents and Path and other Environment Variables as on the old PC.
C:\_Files\SDR - Software Defined Radio\sdrtrunk - 1st working version>java -jar sdr-trunk-all-0.3.4-beta.2.jar
07:26:27.261 INFO i.g.dsheirer.gui.SDRTrunk - ************************************************** ***************** [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - **** sdrtrunk: a trunked radio and digital decoding application *** [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - **** website: https://github.com/dsheirer/sdrtrunk *** [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - ************************************************** ***************** [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - Memory Logging Format: [Used/Allocated PercentUsed%] [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - Host CPU Cores: 16 [16MB/256MB 6%]
07:26:27.266 INFO i.g.dsheirer.gui.SDRTrunk - Host OS Name: Windows 10 [16MB/256MB 6%]
07:26:27.266 INFO i.g.dsheirer.gui.SDRTrunk - Host OS Arch: amd64 [16MB/256MB 6%]
07:26:27.266 INFO i.g.dsheirer.gui.SDRTrunk - Host OS Version: 10.0 [16MB/256MB 6%]
07:26:27.266 INFO i.g.dsheirer.gui.SDRTrunk - Host Max Java Memory: 3 GB [16MB/256MB 6%]
07:26:27.269 INFO i.g.d.util.ThreadPool - Application thread pool created with [16] threads [16MB/256MB 6%]
07:26:27.269 INFO i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\jkres\SDRTrunk [16MB/256MB 6%]
07:26:27.273 INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\jkres\SDRTrunk\SDRTrunk.properties] [16MB/256MB 6%]
07:26:27.273 INFO i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\jkres\SDRTrunk\SDRTrunk.properties] [16MB/256MB 6%]
07:26:27.281 INFO i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\jkres\SDRTrunk\settings\settings.xml] [17MB/256MB 6%]
07:26:27.706 INFO i.g.d.s.m.MixerManager - loading system mixer devices
[LOADED] Output: Primary Sound Driver CHANNELS: [MONO, STEREO]
[LOADED] Output: Headphones (4- C-Media USB Audio Device ) CHANNELS: [MONO, STEREO]
[LOADED] Output: Desk Speakers (Realtek Audio) CHANNELS: [MONO, STEREO]
[LOADED] Output: CABLE Input (VB-Audio Virtual Cable) CHANNELS: [MONO, STEREO]
[LOADED] Input: Primary Sound Capture Driver CHANNELS: [LEFT, RIGHT, MONO]
[LOADED] Input: CABLE Output (VB-Audio Virtual CHANNELS: [LEFT, RIGHT, MONO]
[LOADED] Input: Microphone (4- C-Media USB Audi CHANNELS: [LEFT, RIGHT, MONO]
[10MB/256MB 3%]
07:26:27.708 INFO i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations [10MB/256MB 3%]
07:26:27.896 INFO i.g.d.s.t.TunerManager - LibUSB API Version: 16777474 [11MB/256MB 4%]
07:26:27.897 INFO i.g.d.s.t.TunerManager - LibUSB Version: 1.0.18.10866 [11MB/256MB 4%]
07:26:27.904 INFO i.g.d.s.t.TunerManager - discovered [14] attached USB devices [11MB/256MB 4%]
07:26:27.910 INFO i.g.d.s.t.TunerManager - usb device [413C:301A] NOT LOADED: Unknown Device [12MB/256MB 4%]
07:26:27.910 INFO i.g.d.s.t.TunerManager - usb device [0CF3:E007] NOT LOADED: Unknown Device [12MB/256MB 4%]
07:26:27.911 INFO i.g.d.s.t.TunerManager - usb device [413C:2113] NOT LOADED: Unknown Device [12MB/256MB 4%]
07:26:30.621 INFO i.g.d.s.t.TunerManager - usb device [0BDA:2838] LOADED: RTL2832 SDR/R820T 00000001 [12MB/256MB 4%]
07:26:30.622 INFO i.g.d.s.t.TunerManager - usb device [05E3:0610] NOT LOADED: Unknown Device [12MB/256MB 4%]
07:26:33.318 INFO i.g.d.s.t.TunerManager - usb device [0BDA:2838] LOADED: RTL2832 SDR/R820T VHF-001 [13MB/256MB 5%]
07:26:33.319 INFO i.g.d.s.t.TunerManager - usb device [0D8C:0008] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.320 INFO i.g.d.s.t.TunerManager - usb device [1022:145C] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.321 INFO i.g.d.s.t.TunerManager - usb device [413C:2113] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.321 INFO i.g.d.s.t.TunerManager - usb device [05E3:0610] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.322 INFO i.g.d.s.t.TunerManager - usb device [0764:0501] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.322 INFO i.g.d.s.t.TunerManager - usb device [1022:43B9] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.323 INFO i.g.d.s.t.TunerManager - usb device [05E3:0610] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.324 INFO i.g.d.s.t.TunerManager - usb device [0D8C:0008] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.909 INFO i.g.d.icon.IconManager - loading icons file [C:\Users\jkres\SDRTrunk\settings\icons.xml] [30MB/256MB 11%]
07:26:34.106 INFO i.g.d.p.PlaylistManager - Attempting to load version 2 playlist file [C:\Users\jkres\SDRTrunk\playlist\playlist_v2.xml] [18MB/256MB 7%]
07:26:34.208 INFO i.g.dsheirer.gui.SDRTrunk - starting main application gui [46MB/256MB 17%]
07:26:45.802 INFO i.g.d.c.c.ChannelAutoStartFrame - Starting [3] now - timer invoked [125MB/256MB 48%]
07:26:45.812 ERROR i.g.d.s.t.r.RTL2832Tuner - couldn't provide source channel [126MB/256MB 49%]
at io.github.dsheirer.source.tuner.rtl.RTL2832TunerCo ntroller.write(RTL2832TunerController.java:815)
at io.github.dsheirer.source.tuner.rtl.RTL2832TunerCo ntroller.writeDemodRegister(RTL2832TunerController .java:711)
at io.github.dsheirer.source.tuner.rtl.RTL2832TunerCo ntroller.enableI2CRepeater(RTL2832TunerController. java:615)
at io.github.dsheirer.source.tuner.rtl.r820t.R820TTun erController.setTunedFrequency(R820TTunerControlle r.java:159)
at io.github.dsheirer.source.tuner.frequency.Frequenc yController.setFrequency(FrequencyController.java: 115)
at io.github.dsheirer.source.tuner.frequency.Frequenc yController.setFrequency(FrequencyController.java: 87)
at io.github.dsheirer.source.tuner.TunerController.up dateLOFrequency(TunerController.java:337)
at io.github.dsheirer.source.tuner.TunerController.ge tChannel(TunerController.java:210)
at io.github.dsheirer.source.tuner.rtl.RTL2832Tuner.g etChannel(RTL2832Tuner.java:116)
at io.github.dsheirer.source.tuner.TunerModel.getSour ce(TunerModel.java:304)
at io.github.dsheirer.source.SourceManager.getSource( SourceManager.java:78)
at io.github.dsheirer.controller.channel.ChannelProce ssingManager.startProcessing(ChannelProcessingMana ger.java:213)
at io.github.dsheirer.controller.channel.ChannelProce ssingManager.channelChanged(ChannelProcessingManag er.java:158)
at io.github.dsheirer.controller.channel.ChannelAutoS tartFrame.startChannels(ChannelAutoStartFrame.java :185)
at io.github.dsheirer.controller.channel.ChannelAutoS tartFrame.access$400(ChannelAutoStartFrame.java:40 )
at io.github.dsheirer.controller.channel.ChannelAutoS tartFrame$CountdownTimer.run(ChannelAutoStartFrame .java:241)
at java.base/java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:514)
at java.base/java.util.concurrent.FutureTask.runAndReset(Future Task.java:305)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:305)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1135)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:844)
07:26:45.814 INFO i.g.d.s.tuner.TunerModel - Unable to source channel [853962500] from preferred tuner [RTL2832 SDR/R820T VHF-001] - searching for another tuner [126MB/256MB 49%]
07:26:45.817 ERROR i.g.d.s.t.r.RTL2832Tuner - couldn't provide source channel [126MB/256MB 49%]
at io.github.dsheirer.source.tuner.TunerModel.getSour ce(TunerModel.java:327)
07:26:45.821 ERROR i.g.d.s.t.r.RTL2832Tuner - couldn't provide source channel [127MB/256MB 49%]
07:26:45.881 INFO i.g.d.m.d.p.a.P25AudioModule - JMBE audio conversion library [JMBE Audio Conversion Library v0.3.3] successfully loaded - P25 audio will be available [136MB/256MB 53%]
  #410 (permalink)
Old Today, 7:34 AM
It looks like your JMBE library loaded successfully, so that issue is resolved.
The second issue is your tuner. Does this tuner work ok with other SDR applications like SDR#?
The error indicates that sdrtrunk is trying to set the center frequency and the USB software (libusb) is throwing an error that it can't communicate with the tuner.
If the driver is installed correctly, you may want to try unplugging the tuner and replugging to reset the device.
Denny
  #411 (permalink)
Old Today, 1:00 PM
AB9NN's Avatar
It does start and play audio with work ok with other SDR applications like SDR#. It is a little funky and used to work nearly perfectly (heat issues, etc excepted). When I re-tune I have to stop and re-start the software, and then it is good.
I suspect driver but did unplug and re-plug. When I re-install driver with Zadig.exe it doesn't find the same driver that it used to find. Is there a way to manually install it or otherwise place it where it can be found?
