Since DSD+ 1.090 now supports TCP, how do you set up TCP in Windows 7 to work with FMP? I have never had a need to fiddle with TCP before now.
You have to enter it into both bat files, and with trunking there is more, it's explained in the notes.txt file.
I used -i10000 in my dsd+ bat, and the same # for my fmp bat.
FMP.exe 10000 1 67
how or do you need to set the TCP value in windows? is the sample 20001 for CC or dongle #1 right? How do you find out?
Good question; I would like to know how these values are set or changed in Windows. How does the bat file know that 20001 refers to a TCP value and not something else?
You might check you Firewall application to make sure FMP is not blocked
Is FMP running and listening on port 20002? It should tell you in the FMP console window.When I start up VC (DSDPlus), I get this error:
Connecting to TCP port 20002...
TCP connect error = 10061
(no connection could be made because the target refused it)
Is FMP unblocked in the Windows firewall? Start / Control Panel / Windows Firewall (on XP at least); FMP has to be in the exceptions list and it has to have a checkmark ("allowed") next to its name.
Not really. UDP also sits on top of the Windows IP stack so the same firewall concerns apply.In the meantime, this seems like another good argument for using UDP instead of TCP for intracomputer communication between programs.
