Unitrunker installation error
ctpd845
Martin, Ohio
I tried to download unitrunker on a computer running windows 10 but when I open the program I get an error message that says "No working folder access. Invalid installation or shortcut. Program will exit".
Any ideas, as I have tried uninstalling and re-installing several times with no luck. This is on verison 1.0.32.7
SCPD
QRT
Virginia
That message results from running the program in the same folder as your data.
For example, browsing to the EXE under Program Files(x86) in Windows Explorer and double-clicking it there.
Running the program through a shortcut that does not specify a working folder will give you this warning popup too.
Try this:
1. Go to control panel and remove all installations of the program.
2. Delete any shortcuts left behind on your desktop, task bar or start menu.
3. Install program.
4. Use the Start menu to launch the program.
eaf1956
Evansville, IN
I am running WIN 7 and tried to install Unitrunker 1.0.32.7 but it keeps telling me the older version can't be uninstalled. It keeps asking for the Unitrunker 1.0.32.5.msi installation file. There are no UNITRUNKER folders on the C drive. From what I can research there is no Unitrunker 1.0.32.5.msi version
