I've just downloaded the new public version of DSDPlus, which they say will track trunking. I'm trying to set it up for the Harrison County Public Service Network here in Mississippi. I'm trying to to this without having to use Unitrunker. I wonder if someone can take a look at my bat files and my DSDPlus.frequencies file to see if they see something I got wrong. The updated dsdplus program says you can do it without using virtual audio cable or VB-Cable, so that's what I'm trying to do. I'm using 2 SDR USB dongles.
CC.Bat
DSDPlus -rc -i20001 -v3 -wsl400.2 -wss100.200 -wel0.1 -wcl0.445 -wes400.520 >>CC.log
FMP-CC.Bat
FMP -i1 -o20001 -P55.0 -f851.400
VC.Bat
DSDPlus -rv -Pwav -i20002 -v3 -wsl400.210 -wss100.200 -wel172.522 -wcl528.0 >>VC.log
FMP-VC.Bat
FMP -i2 -o20002 -P55.0 -rv
My DSDPlus.frequencies
; DSD+ frequency file
; you can edit this file while DSD+ is running
; line format:
; protocol, networkID, siteNumber, OTAchannelNumber, TXfrequency, RXfrequency, sortOrder
; for TIII, siteNumber format = area.site
; use site number = 0 for network-wide definition
; use 0.0 for unknown frequencies
; use sort order = 0 to sort by OTA channel number
; protocols:
; D-Star
; IDAS
; NEXEDGE48
; NEXEDGE96
; dPMR
; DMR
; Cap+
; Con+
; TIII
; P25
; ProVoice
ProVoice, 977, 1, 1, 851.15000, 851.15000, 0
ProVoice, 977, 1, 2, 851.40000, 851.40000, 0
ProVoice, 977, 1, 3, 851.67500, 851.67500, 0
ProVoice, 977, 1, 4, 851.95000, 851.95000, 0
ProVoice, 977, 1, 5, 852.20000, 852.20000, 0
ProVoice, 977, 1, 6, 852.56250, 852.56250, 0
ProVoice, 977, 1, 7, 852.85000, 852.85000, 0
ProVoice, 977, 1, 8, 853.10000, 853.10000, 0
ProVoice, 977, 1, 9, 853.51250, 853.51250, 0
ProVoice, 977, 1, 10, 853.76250, 853.76250, 0
ProVoice, 977, 1, 11, 851.81250, 851.81250, 0
ProVoice, 977, 1, 12, 852.27500, 852.27500, 0
ProVoice, 977, 1, 13, 853.38750, 853.38750, 0
ProVoice, 977, 1, 14, 853.65000, 853.65000, 0
ProVoice, 977, 1, 15, 852.33750, 852.33750, 0
ProVoice, 977, 1, 16, 852.78750, 852.78750, 0
ProVoice, 977, 1, 17, 853.26250, 853.26250, 0
ProVoice, 977, 1, 18, 851.88750, 851.88750, 0
ProVoice, 977, 1, 19, 852.67500, 852.67500, 0
ProVoice, 977, 1, 20, 851.21250, 851.21250, 0
Here is also my CC.log and VC.log files.
CC.Log
DSD+ 1.101pt
Program role is control/rest channel decoder
Source audio waveform window origin set to (400,2)
Source audio waveform window dimensions set to 100x200
Event log window origin set to (0,1)
Channel window origin set to (0,445)
Event log window dimensions set to 400x520
Appending synthesized audio to file 'CC-DSDPlus.wav'
20 frequency records loaded
0 radio records loaded
0 group records loaded
0 site records loaded
1 network record loaded
Initiating TCP connection to 127.0.0.1:20001...
Connected to 127.0.0.1:20001
audio output device #1 = 'Speakers (Realtek High Definiti'
audio output device #2 = 'LCD TV-4 (NVIDIA High Definitio'
audio output device #3 = 'CABLE-A Input (VB-Audio Cable A'
audio output device #4 = 'Realtek Digital Output (Realtek'
audio output device #5 = 'CABLE-B Input (VB-Audio Cable B'
audio output device #6 = 'CABLE Input (VB-Audio Virtual C'
audio output device #1 (Speakers (Realtek High Definiti) initialized
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
TCP cleanup
*partial* decoding score = 0
VC.Log
DSD+ 1.101pt
Program role is voice channel decoder; audio modes set to mono
Assuming FMP is signal source; auto polarity detect is disabled
Writing synthesized audio to per-call wav files
Source audio waveform window origin set to (400,210)
Event log window origin set to (172,522)
Channel window origin set to (528,0)
Appending synthesized audio to file 'VC-DSDPlus.wav'
Initiating TCP connection to 127.0.0.1:20002...
Connected to 127.0.0.1:20002
TCP cleanup
Thanks in advance.
CC.Bat
FMP-CC.Bat
VC.Bat
FMP-VC.Bat
; line format:
; protocols:
; D-Star
; IDAS
; NEXEDGE48
; NEXEDGE96
; dPMR
; DMR
; Cap+
; Con+
; TIII
; P25
; ProVoice
CC.Log
DSD+ 1.101pt
TCP cleanup
VC.Log
DSD+ 1.101pt
TCP cleanup
Thanks in advance.
