FMP Frequency Lists
Every time FMP is retuned, FMP will search the CSV files specified in FMP.cfg
for matching in-range frequency records. The CSV files can be created from
government data sources or Internet sites.
Each line in the files holds one TX frequency record or a record for
a TX/RX frequency pair. Each line contains eight fields. Text fields must
use enclosing quote characters. Fields must be separated by a comma and
a space.
Example data:
; TXfreq, RXfreq, Licensee, Location, Latitude, Longitude, first emission mode, second emission mode
461.1625, 466.1625, "example licensee", "example location", 35.1028, -80.9420, "16K0F3E", ""
When in-range matches are found, FMP displays them, sorted by distance,
in FMP's console window. FMP also passes the closest match to FMP-Map.
I wouldn't characterize it as complaining, since it's an optional file, but whatever...Anyway, is there any help for the file Primary "FMPA-FreqList.csv"? The program is complaining that it doesn't exist, but there is no indication of how to create it or the format it uses. Is it the same as the frequencies file?
I just tried and it's not working for me either. Wait - it's not working when I use the TCP link feature. When I use VB-Cable and SDR# it works. Go figure.In this release, I think, they have broken file split feature.
When I use -I60 option dsdplus creates one file and does not split it every hour like it did before.
Does anybody can confirm this problem or is it me doing something wrong?
Maybe they're on a beach somewhere warm? Maybe they expected that an easy question like that would be answered by someone else? Oh look - it was.I'm surprised at the lack of support so far. Since the Fast Lane came out, it looks like those are the only people who are getting answers. It's been 4 days since I asked my question above.
I'm looking at that file right now. It says:Thanks. There is no such reference in the file FMPA.TXT
Wow. They release a fully functional public version and you're complaining. Oh, I forgot - they're not Uniden.And with the Fast Lane support, I would expect the same for the public release like it was before FL. It's almost like the non-FL users got kicked to the curb.
The info is in the text file.Besides, that should have been in the TXT file.
No, it's an optional file and FMPA runs fine without it.Hopefully the word will get back and it will be added, as it's a critical piece of info needed to make FMPA work.
Try FMP --> VB Cable --> DSD+
Mine seems to work well, still a bit of hit or miss with stopping on an active channel all the time but it scans and most of the time stops with voice activity in the selected mode.
My FMPA batch file is:
FMPA -i1 -o20004 -f462.1625
I then run DSDPlus with:
DSDPlus -i20004 -v3 -fa -E -T -_1 -wsl250.1400 -wel550.1000 -wcl350.1000 -wes200.875 >>AirspyDSD.log
My FMPA.SCANLIST file is:
454.19375 Con+ Site26
454.20625 Con+ Site26
454.21875 Con+ Site26
454.23125 Con+ Site26
chris
