Has anyone tried installing OP25 on Windows 10 using the new Bash shell?
cellphone Silent key. Premium Subscriber Joined Dec 28, 2002 Messages 1,811 Location Ahwatukee, AZ (Phoenix) Jul 7, 2016 #1 Has anyone tried installing OP25 on Windows 10 using the new Bash shell?
AggieCon Member Premium Subscriber Joined Nov 25, 2015 Messages 1,448 Location Texas Jul 7, 2016 #2 I run OP25 using VM Ware with Ubuntu on Windows 10. No problems here. Those with marginal computers reported difficultly installing and with a audio buffer issue.
cellphone Silent key. Premium Subscriber Joined Dec 28, 2002 Messages 1,811 Location Ahwatukee, AZ (Phoenix) Jul 7, 2016 #3 How about running natively on Windows 10 using the new Windows Subsystem for Linux?
AggieCon Member Premium Subscriber Joined Nov 25, 2015 Messages 1,448 Location Texas Jul 7, 2016 #4 No, sorry, I guess I misunderstood. I have not. Unless you can figure out a way to get graphical UI, I am not sure if it will work. What are the specifications of your computer?
cellphone Silent key. Premium Subscriber Joined Dec 28, 2002 Messages 1,811 Location Ahwatukee, AZ (Phoenix) Jul 8, 2016 #5 Hardware should not be a problem as it is an i7 32GB Ram. Take a look at this for running Linux GUI apps. I have not had time to play with it yet. http://windowsclan.com/developers-running-linux-gui-apps-windows-10-using-bash/
AggieCon Member Premium Subscriber Joined Nov 25, 2015 Messages 1,448 Location Texas Jul 8, 2016 #6 cellphone said: Hardware should not be a problem as it is an i7 32GB Ram. Click to expand... Good deal. Same here. Others haven't had the best luck with i3, less than 12GB, etc. I will check out the link.
N N3OIA Newbie Joined Mar 30, 2016 Messages 4 Jun 21, 2017 #7 Any progress with this? AFAIK there's no audio capabilities for the WSL...and I'm not sure if it could access an SDR by USB either.
