I'm able to decode DMR with DSD+ using SDR#. I not able to decode using the same setup with P25, I've read through the forums and founds some really good tips on decoding P25. But no luck yet.
If you're trying to decode a Trunked System (as opposed to a single conventional P-25 frequency) you'll need two dongles, and you can't use SDR#. Rather, along with DSD+ you need Unitrunker or alternatively FMP/FMP24.
