TRUNK88 Voice Control wrong Step Size
jasoyeom
Norfolk County
I'm using Trunk88 to control my BCD396XT on the Ontario Fleetnet system. It works fine except that on the scanner the frequencies are not the same as what Trunk88 is monitoring.
Eg: 143.160 on trunk88 shows up as 143.1625 on the scanner. 143.4125 should be 143.415 etc.
I've checked the config files and they are setup properly.
Jason
jasoyeom
Norfolk County
Since Trunk88 is controlling the scanner it's selecting the frequency and not anything programmed into the scanner. I've looked over all the settings in Trunk88 but nothing about step size.
