Old 08-11-2017, 3:01 PM
Default TRUNK88 Voice Control wrong Step Size
I'm using Trunk88 to control my BCD396XT on the Ontario Fleetnet system. It works fine except that on the scanner the frequencies are not the same as what Trunk88 is monitoring.
Eg: 143.160 on trunk88 shows up as 143.1625 on the scanner. 143.4125 should be 143.415 etc.
I've checked the config files and they are setup properly.
Jason
Old 08-11-2017, 6:53 PM
Homeboys-Scanna's Avatar
Does the scanner have a step size setting that needs to be set to 5 kHz?
"Copy, 132 and Bush, cover's code 3."
Old 08-11-2017, 7:29 PM
Since Trunk88 is controlling the scanner it's selecting the frequency and not anything programmed into the scanner. I've looked over all the settings in Trunk88 but nothing about step size.
Old 08-11-2017, 7:30 PM
Those Unidens are a PITA. You probably have to just live with being 2.5 kHz off, which likely isn't a problem anyway.
Old 08-11-2017, 9:15 PM
PITA is right but it's working ok. Sometimes it's delayed decoding the P25 but it will do.
Thanks.
