Hello, I've been doing some reading about how to use DSD+, but i've ran into some trouble. I work for a radio company and I have successfully been able to get DSD+ to work with RSP2Pro and SDR Console for one of my coworkers. My problem now is, I have a Uniden BR330T Scanner with the discriminator mod done. I am using a stereo cable to connect the audio from the scanner to my computer line-in port. I also have the scanner plugged in via USB so I can program it remotely via teamviewer when I am at work.
I have a big setup i'm doing, i'm going to route all of this through VAC cables to a teamspeak server so I can listen to it on my phone but right now I just want to get DSD Decoding my audio
Main issue - Uniden BR330T - DSD+ - VB cable software - NXDN 9600
I can hear the digital through my speakers, and the DSD+ Audio Scope shows audio waves. However, DSD+ does not say it is decoding the audio, it doesn't say syncing or anything. I used DSD+ to record raw audio to test that it is receiving the audio and hearing it, but it just isn't decoding it. I have the correct input set as Line-In and the output to my speakers for now, that will change when I get it working. I am lost and don't know what to do now. My DSD Shortcut has the following parameters ( C:\DSDPlus\DSDPlus.exe -o2L -i1M )
I will also attach the raw audio I recorded with DSD+ if I need to. ( It shows the audio is too big, if you need it, provide me with a place to upload it that is allowed by the forums ).
