tubular031
- Joined
- Oct 9, 2017
- Messages
- 17
Can someone point me to something that can help me monitor a Motorola Type II Smartnet system?
The system I want to monitor is this one
https://www.radioreference.com/apps/db/?sid=15
I can not seem to figure out how to monitor it. I can hear the control channel fine with SDR# and uniturnker pops a site window when I point to the control channel but I can not hear anything. Its an analog system so shouldnt I hear it on unitrunker? I do have 2 rtl-sdr v3 dongles hooked up and unitrunker is set to use both of them, one as signal and one as voice.
I tried SDRTrunk and that did not seem to do anything. I am able to use SDRtrunk to hear and decode some p25 nontrunked frequencies around here and also a p25-1 system that I also decode with OP25.
I have OP25 running on ubuntu monitoring a p25-2 and also a p25-1 system. That was quite a battle to get working. For the noobs reading this from a google search, keep at it and take lots of breaks and you will get it working eventually....
In a perfect world op25 would monitor it but I dont think that is possible since this is not p25..
Thank you for your help.
