Do you remember how you linked FMP24 with SDRUno?
I remember that i _didn't_ link FMP24 with SDRUno. FMP24 gets linked (via TCP) with the second running copy of DSPLus serving as the voice following receiver.
SDRPlay+SDRUno gets linked with the first running copy of DSDPlus via VAC (Virtual Audio Cable) or perhaps VB Cable.
You need to do some searching in the forums rather than expecting somebody to provide you with an A-Z complete tutorial on it. These types of things are talked about on the forums here regularly.
Sorry, but I don't use my SDRPlay anymore. I only tried it one time before figuring out that it doesn't meet my needs. But rest assured, it can be used in combination with SDRUno, two running copies of DSDPlus, FMP24, and an RTL dongle for trunked voice following.
mike
PS: Please read every .TXT file that came with DSDPlus, multiple times. You need to understand the available switches and options, as well as the workflow of FMP24-->tcpip-->DSDPlus and SDRUno-->VAC-->DSDPlus. Be sure to read the .BAT files too. There are sample batch files to use with two RTL dongles. You would modify the those batch files to work with what you have.
