Odd Behavour with new fastlane
W5RGP
Charlotte Tn
I removed all entrys from my groups file instaed of having to go change all the nxdn to nxdn48
but it is still creating some duplicates on its own some with the network id some without
anyone know why it would be duplicating some sites and not others?
it is the Tn District 7 homeland site
https://www.radioreference.com/apps/db/?sid=8220
; DSD+ 2.71; group records
; you can edit this file while DSD+ is running
; line format: protocol, networkID, group, priority, override, hits, timestamp, "group alias"
NEXEDGE48, 0, 51100, 50, Normal, 5, 2018/01/12 14:50, ""
NEXEDGE48, 0, 52005, 50, Normal, 10, 2018/01/12 14:53, ""
NEXEDGE48, 0, 52100, 50, Normal, 3, 2018/01/12 14:45, ""
NEXEDGE48, 0, 53100, 50, Normal, 32, 2018/01/12 14:52, ""
NEXEDGE48, 0, 59100, 50, Normal, 5, 2018/01/12 14:46, ""
NEXEDGE48, 171, 51100, 50, Normal, 16, 2018/01/12 14:51, ""
NEXEDGE48, 171, 52005, 50, Normal, 36, 2018/01/12 14:53, ""
NEXEDGE48, 171, 52100, 50, Normal, 18, 2018/01/12 14:53, ""
NEXEDGE48, 171, 52300, 50, Normal, 2, 2018/01/12 14:51, ""
NEXEDGE48, 171, 53100, 50, Normal, 60, 2018/01/12 14:53, ""
NEXEDGE48, 171, 55900, 50, Normal, 1, 2018/01/12 14:52, ""
NEXEDGE48, 171, 59100, 50, Normal, 14, 2018/01/12 14:51, ""
; 12 records; 0 aliases
slicerwizard
Toronto, Ontario
When you start up DSD+, it's probably seeing call grants before it's seeing the network ID.
Or you're just monitoring voice channels that broadcast no network information?
W5RGP
Charlotte Tn
so maybe some radios are mis configured? and just not broadcasting all info?
that may be why when i lockout some sites i still get radio traffic from those site then
slicerwizard
Toronto, Ontario
No. I didn't say that.
Sorry, I have no idea what your setup looks like and how you're locking out sites. One normally doesn't lock out any sites, so I don't know what you really mean.
W5RGP
Charlotte Tn
I meant locking out groups ill be home in a little bit will repost a copy of my groups file again after running most of the day
its like its creating 2 sets of the same groups 1 with the network at 0 and the other one with the correct one of 171
i'm not home alot im an over the road truck driver so i dont get to mess with dsd for a while at times and was just trying to make sure i hadnt forgot something or missed something
W5RGP
Charlotte Tn
This is after monitoring the same control ch all day the cc was for Dickson PD
but it picked up a ton of other groups
NEXEDGE48, 0, 51100, 50, Normal, 56, 2018/01/13 17:53, ""
NEXEDGE48, 0, 51200, 50, Normal, 25, 2018/01/13 17:45, ""
NEXEDGE48, 0, 52001, 50, Normal, 74, 2018/01/13 17:25, ""
NEXEDGE48, 0, 52003, 50, Normal, 3, 2018/01/13 13:20, ""
NEXEDGE48, 0, 52005, 50, Normal, 49, 2018/01/13 17:33, ""
NEXEDGE48, 0, 52100, 50, Normal, 90, 2018/01/13 17:50, ""
NEXEDGE48, 0, 52200, 50, Normal, 45, 2018/01/13 17:49, ""
NEXEDGE48, 0, 52300, 50, Normal, 7, 2018/01/13 17:39, ""
NEXEDGE48, 0, 52309, 50, Normal, 2, 2018/01/13 16:50, ""
NEXEDGE48, 0, 52310, 50, Normal, 2, 2018/01/13 17:38, ""
NEXEDGE48, 0, 52313, 50, Normal, 1, 2018/01/13 16:49, ""
NEXEDGE48, 0, 52315, 50, Normal, 1, 2018/01/13 16:58, ""
NEXEDGE48, 0, 52316, 50, Normal, 4, 2018/01/13 17:07, ""
NEXEDGE48, 0, 53100, 50, Normal, 28, 2018/01/13 17:49, ""
NEXEDGE48, 0, 53300, 50, Normal, 2, 2018/01/13 13:33, ""
NEXEDGE48, 0, 54105, 50, Normal, 24, 2018/01/13 17:51, ""
NEXEDGE48, 0, 59100, 50, Normal, 41, 2018/01/13 17:52, ""
NEXEDGE48, 0, 59200, 50, Normal, 14, 2018/01/13 13:33, ""
NEXEDGE48, 0, 59300, 50, Normal, 18, 2018/01/13 13:34, ""
; Homeland 7
NEXEDGE48, 171, 13, 50, L/O, 45, 2018/01/13 13:05, ""
NEXEDGE48, 171, 15, 50, L/O, 14, 2018/01/12 15:55, ""
NEXEDGE48, 171, 35, 50, L/O, 29, 2018/01/13 10:47, ""
NEXEDGE48, 171, 1001, 50, L/O, 14, 2018/01/13 16:31, ""
NEXEDGE48, 171, 1002, 50, L/O, 6, 2018/01/12 16:01, ""
NEXEDGE48, 171, 1003, 50, L/O, 6, 2018/01/12 16:01, ""
NEXEDGE48, 171, 1006, 50, L/O, 23, 2018/01/13 16:34, ""
NEXEDGE48, 171, 2003, 50, L/O, 3, 2018/01/13 12:02, ""
NEXEDGE48, 171, 2006, 50, L/O, 26, 2018/01/13 16:33, ""
NEXEDGE48, 171, 2007, 50, L/O, 3, 2018/01/13 12:02, ""
NEXEDGE48, 171, 51001, 50, L/O, 6, 2018/01/13 13:04, ""
NEXEDGE48, 171, 51003, 50, L/O, 3, 2018/01/13 17:02, ""
NEXEDGE48, 171, 51006, 50, L/O, 5, 2018/01/13 7:04, ""
NEXEDGE48, 171, 51018, 50, L/O, 8, 2018/01/13 11:09, ""
NEXEDGE48, 171, 51019, 50, L/O, 3, 2018/01/13 11:09, ""
NEXEDGE48, 171, 51100, 50, L/O, 1231, 2018/01/13 17:54, ""
NEXEDGE48, 171, 51200, 50, L/O, 240, 2018/01/13 17:45, ""
NEXEDGE48, 171, 52001, 50, Normal, 370, 2018/01/13 17:48, ""
NEXEDGE48, 171, 52002, 50, Normal, 8, 2018/01/13 17:09, ""
NEXEDGE48, 171, 52003, 50, Normal, 13, 2018/01/13 17:07, ""
NEXEDGE48, 171, 52004, 50, Normal, 30, 2018/01/13 17:09, ""
NEXEDGE48, 171, 52005, 20, High, 1557, 2018/01/13 17:53, "Dickson PD"
NEXEDGE48, 171, 52006, 50, Normal, 3, 2018/01/13 17:05, ""
NEXEDGE48, 171, 52007, 50, Normal, 7, 2018/01/12 18:57, ""
NEXEDGE48, 171, 52100, 10, High, 2166, 2018/01/13 17:53, "Sheriff"
NEXEDGE48, 171, 52101, 50, Normal, 11, 2018/01/13 7:19, ""
NEXEDGE48, 171, 52200, 50, Normal, 891, 2018/01/13 17:49, ""
NEXEDGE48, 171, 52300, 50, High, 173, 2018/01/13 17:45, ""
NEXEDGE48, 171, 52307, 50, Normal, 15, 2018/01/13 17:00, ""
NEXEDGE48, 171, 52308, 50, Normal, 32, 2018/01/13 17:03, ""
NEXEDGE48, 171, 52309, 50, Normal, 15, 2018/01/13 17:00, ""
NEXEDGE48, 171, 52310, 50, Normal, 10, 2018/01/13 17:37, ""
NEXEDGE48, 171, 52311, 50, Normal, 3, 2018/01/12 18:17, ""
NEXEDGE48, 171, 52312, 50, Normal, 17, 2018/01/13 7:31, ""
NEXEDGE48, 171, 52313, 50, Normal, 16, 2018/01/13 16:49, ""
NEXEDGE48, 171, 52315, 50, Normal, 11, 2018/01/13 17:02, ""
NEXEDGE48, 171, 52316, 50, Normal, 11, 2018/01/13 17:06, ""
NEXEDGE48, 171, 52317, 50, Normal, 15, 2018/01/13 9:42, ""
NEXEDGE48, 171, 53100, 50, L/O, 432, 2018/01/13 17:48, ""
NEXEDGE48, 171, 53300, 50, L/O, 69, 2018/01/13 17:49, ""
NEXEDGE48, 171, 54105, 50, L/O, 353, 2018/01/13 17:51, ""
NEXEDGE48, 171, 54200, 50, L/O, 1, 2018/01/12 17:56, ""
NEXEDGE48, 171, 54300, 50, L/O, 3, 2018/01/13 13:27, ""
NEXEDGE48, 171, 55100, 50, L/O, 343, 2018/01/13 16:37, ""
NEXEDGE48, 171, 55101, 50, L/O, 3, 2018/01/12 15:53, ""
NEXEDGE48, 171, 55105, 50, L/O, 14, 2018/01/12 15:52, ""
NEXEDGE48, 171, 55200, 50, L/O, 163, 2018/01/13 16:36, ""
NEXEDGE48, 171, 55205, 50, L/O, 6, 2018/01/12 15:50, ""
NEXEDGE48, 171, 55300, 50, L/O, 179, 2018/01/13 16:36, ""
NEXEDGE48, 171, 55301, 50, L/O, 3, 2018/01/12 15:38, ""
NEXEDGE48, 171, 55900, 50, L/O, 8, 2018/01/13 7:05, ""
NEXEDGE48, 171, 55901, 50, L/O, 18, 2018/01/13 11:39, ""
NEXEDGE48, 171, 55902, 50, L/O, 6, 2018/01/12 16:10, ""
NEXEDGE48, 171, 57001, 50, L/O, 14, 2018/01/13 16:32, ""
NEXEDGE48, 171, 57101, 50, L/O, 13, 2018/01/13 16:35, ""
NEXEDGE48, 171, 57200, 50, L/O, 11, 2018/01/13 16:36, ""
NEXEDGE48, 171, 59000, 50, L/O, 110, 2018/01/13 12:58, ""
NEXEDGE48, 171, 59100, 50, L/O, 357, 2018/01/13 17:53, ""
NEXEDGE48, 171, 59200, 50, L/O, 135, 2018/01/13 13:34, ""
NEXEDGE48, 171, 59300, 50, L/O, 76, 2018/01/13 16:18, ""
NEXEDGE48, 171, 61155, 50, L/O, 1, 2018/01/12 14:53, ""
NEXEDGE48, 54622, 52200, 50, Normal, 1, 2018/01/13 9:49, ""
; 81 records; 2 aliases
not sure why forum misaligned the comma's but they are all lined up in my groups file
