Unitrunker Event Logs
TexScan780D
While running Unitrunker and I select Browse Events Logs an notice every directory is empty, so where are my events logs?
nd5y
Wichita Falls, TX
The logs should be in the same folder as your unitrunker.xml file. That location depends on the OS version. The log folders will be empty unless you have logging enabled.
druhe
Southwest Pa
Tom, Thanks for the reply. Where to I enable logging ? I've looked unable to find it
druhe
Southwest Pa
Found it, once I realized the function had to be enabled I dug a little deeper. Thanks for all your help
