Old 02-01-2018, 1:36 AM
Default Hytera GPS decoding by DSD+...
Dear All
I want to know could I use LRRP in DSD+ to decode a GPS data from a Hytera device? I have seen someone said it can be done if disable the "data compression" of GPS setting on CPS. After tested some days I still can't decode any GPS data on my LRRP. Does anyone have an ideal to help me? Thank a lot...
PS: I use the GPS location report application from Hytera and every terminals can report their location normally...
Old 02-01-2018, 7:19 AM
mtindor's Avatar
OH/WV DB Admin
For starters, you should capture a DSDPlus raw audio file (using the "r" option, which will write to DSDPlus-Raw-Audio*.wav). Capture 20-30 MB of data from the control channel at a time when the site is very active and you know GPS is being sent.
Send the resultant file to dsdplusfastlane@gmail.com . If the file is too big, upload it somewhere and then send the link to the file to dsdplusfastlane@gmail.com .
Mike / AA8IA
PSR800/PRO197/BCD436HP/BCD536HP
