DSDPlus Repeater Maps
vince48
Central Valley, CA.
Greetings
the newest version DSDPlus indicates it will write to file the repeater map:
Repeater maps are written to text files.
The file name format is "ConP <NID> Network Repeater Map v<mapVersion>.txt"
Can someone decipher the above file name convention and where in gods creation is it located?
TIA
cg
Connecticut
if the system you are monitoring updates the frequencies in the radios by transmitting a network map, DSDPlus will create a copy of it in your DSDPlus folder. In 8 months of monitoring a very active system, I have downloaded it only once. The frequencies don't change very often, I caught it because of a new site being added.
The version change is simply to show the newest one.
chris
dave3825
Suffolk County NY
Greetings
TIA
What version are you referring to as the newest? I ask because that was added in DSD+ 2.29.
You actually asked about this a year ago.
DSDPlus - Network Repater Map
vince48
Central Valley, CA.
2.84 Thanks Dave, but i just don't understand the file name that the repeater map is written too and where.
slicerwizard
Toronto, Ontario
Well, you should know the network ID of whatever Con+ system you're monitoring,
so "ConP thatNetworkID Network Repeater Map vsomeNumber.txt"
and it should be in your DSD+ folder.
Probably shouldn't worry about it too much unless the event log indicates that a file was created.
