Old 02-01-2018, 6:54 PM
vince48's Avatar
Default DSDPlus Repeater Maps
Greetings
the newest version DSDPlus indicates it will write to file the repeater map:
Repeater maps are written to text files.
The file name format is "ConP <NID> Network Repeater Map v<mapVersion>.txt"
Can someone decipher the above file name convention and where in gods creation is it located?
TIA
Old 02-01-2018, 8:21 PM
cg cg is offline
if the system you are monitoring updates the frequencies in the radios by transmitting a network map, DSDPlus will create a copy of it in your DSDPlus folder. In 8 months of monitoring a very active system, I have downloaded it only once. The frequencies don't change very often, I caught it because of a new site being added.
The version change is simply to show the newest one.
chris
Old 02-01-2018, 10:22 PM
dave3825's Avatar
Originally Posted by vince48 View Post
Greetings
TIA
What version are you referring to as the newest? I ask because that was added in DSD+ 2.29.
You actually asked about this a year ago.
DSDPlus - Network Repater Map
DMR436HP Br330T Pro 93 Pro 95
Arc330Pro ProScan Freescan BCDX36HP Easy Manual Id Tracker
Old 02-01-2018, 10:30 PM
vince48's Avatar
2.84 Thanks Dave, but i just don't understand the file name that the repeater map is written too and where.
Old 02-02-2018, 12:03 AM
Well, you should know the network ID of whatever Con+ system you're monitoring,
so "ConP thatNetworkID Network Repeater Map vsomeNumber.txt"
and it should be in your DSD+ folder.
Probably shouldn't worry about it too much unless the event log indicates that a file was created.
Old 02-02-2018, 1:10 PM
vince48's Avatar
Thank you slicerwizard, you are always wiling to share your knowledge and being helpful.
