Old 02-04-2018, 5:07 PM
Default DSDplus fastlane - FMP24 troubles
Hey guys,
What does this mean? All of a sudden I am getting this error 'Can't create spectrum window (size too large?).
Also, I'm not getting the data that FMP24-CC.bat tells FMP24-VC.bat the frequency to tune to. Any idea how to fix these two issues?
Lastly, I'm not getting any audio from FMP24-VC.bat that is supposed to go to DSDplus via VC.bat.
Update:
Found the issue. FMP24 is NOT following the frequencies. It's just sitting at f: 0.0000000
Old 02-04-2018, 11:21 PM
frazpo's Avatar
Paste your command lines from each application.
BCD436 - TRX1 - SDR - 890XLT
Old 02-05-2018, 10:46 AM
I just deleted everything and tried again. It looked like I was off by a digit with the -i and -o switches for the TCP ports.
Also, I think FMP24 couldn't create the spectrum window because I launched it from a batch file with the 'start /min' command.
Old 02-05-2018, 9:59 PM
Yup, just tried it and get the same error message. You can use FMP24 -_3 if you want the FMP24 windows to minimize at startup.
