Old 02-05-2018, 3:04 PM
Default DSDplus fastlane - audio quality
Hey guys,
I'm listening to a Cap+ system that has all DMR but the audio playback keeps breaking up at times and sounds like a robot. Is there a way I can improve the playback quality?
The signal is very strong so it's not that.
Old 02-05-2018, 4:09 PM
Play with the input volume and centering of the signal. Also try a raw recording and run dsdtune on it.
Old 02-05-2018, 10:04 PM
Check CPU loading with Windows Task Manager. Is any process maxing out?
What are the system specs? Processor? Clock speed?
Provide a raw audio sample; then others can see where the problem is in the processing chain.
Old 02-06-2018, 10:55 AM
It's an older Windows 8 Samsung laptop that's now running Windows 10.
I believe it's an 3rd generation i5. Can't remember the specs but I'll look it up.
Also, might be CPU. I was running VNC on it to remotely see what's going on. That can make it stutter at times.
Old 02-08-2018, 3:22 PM
I've lowered the volume in FMP24 and the audio coming from DSDplus is a bit better. For DMR, it should be 12.5 or 7.6 kHz wide?
Old 02-08-2018, 5:56 PM
I always use 7.6; seems to work ok.
