DSDPlus Trunking question
bravo14
Polk County FL
Can I trunk track freqs on DSDPlus scan for freqs for a system or do I need to have sharp for control channel and run dsdplus?
thewraith2008
Can you rephrase that.
For best results, with 2 dongles, your setup should be (using TCP):
FMP24 set up as CC
DSDPlus setup as CC
FMP24 set up as VC
DSDPlus setup as VC
CC (Control Channel) setup follows control activity
VC (Voice Channel) setup responds to CC and follows voice activity.
You still need to fill in the record files (.frequencies, .sites, .networks)
bravo14
Polk County FL
FMP24 set up as CC
DSDPlus setup as CC
FMP24 set up as VC
DSDPlus setup as VC
I do have 2 dongles. I do use the fmp cc/vc and dsdplus. Also have the tiles set up still no luck
DRL-XM43
Durham Region
No I have the freqs just to need to scan them
Then you would put the freqs into a FMP(24) scanfile.
This format
770.50625 P25 DELAY=4 Toronto Emergency Services North C
769.93125 P25 DELAY=4 Toronto Emergency Services South C
Then run a batchfile similar to this...
:DSD+ Switches
: -fa Auto-detect all protocols / frame types except dPMR [-fa]
: -fd Decode D-STAR (no audio)
: -fn Decode NXDN4800 (Kenwood NEXEDGE and Icom IDAS)
: -fN Decode NXDN9600 (Kenwood NEXEDGE)
: -fr Decode DMR/MotoTRBO (TDMA inputs + both output slots)
: -f1 Decode P25 Phase 1
: -fx Decode X2-TDMA
: -fp Decode ProVoice
: -fm Enable dPMR decoding (no audio):FMP24-CC.bat:
:FMP24-CC.bat: ***"-fxxx.xxx"***
Start FMP24 -i1 -b9.5 -rc -P0.8 -g49.6 -s1 -o20001 -_1 -wsl000.40
:DSD-CC.bat:
Start DSDPlus -e -rc -f1 -i20001 -v4
:FMP24-VC.bat:
Start FMP24 -i2 -b9.5 -P0.8 -g49.6 -o20002 -rv -_1 -wsl250.40
:DSD-VC.bat:
Start DSDPlus -e -rv -f1 -i20002 -v4
of course change the variables to suit your needs.
bravo14
Polk County FL
Here is what I have in
cc.bat DSDPlus -rc -i3 -v3 -wsl400.2 -wss100.200 -wel0.1 -wcl0.445 -wes400.520 >>CC.log
fmp-cc.bat 4 1 20.0 452.625
fmp-vc.bat FMP 3 2 20.0 99.99999999
vc.bat DSDPlus -rv -Pwav -i2 -o1 -v3 -wsl400.210 -wss100.200 -wel172.522 -wcl528.0 >>VC.log
Freq section
; Regional Domestic Security Task Force
P25, BEE00.292, 1.14, 0, 769.25625, 799.25625, 0
P25, BEE00.292 1.14, 0, 770.28125, 800.28125, 0
P25, BEE00.292, 1.14, 0, 771.38125, 801.38125, 0
; PowerSouth Energy Cooperative
Con+, 164, 18, 0, 451.0625, 456.0625 0
Con+, 164, 2, 0, 461.6000, 466.6000 0
Con+, 164, 11, 0, 452.6250, 457.6250, 0
Con+, 164, 11, 0, 451.9250, 456.9250, 0
Con+, 164, 11, 0, 451.0750, 456.0750, 0
Con+, 164, 28, 0, 451.7500, 456.7500, 0
COn+, 164, 28, 0, 452.1000, 457.1000, 0
Con+, 164, 28, 0, 452.7250, 457.7250, 0
slicerwizard
Toronto, Ontario
Do you really just have a bunch of numbers? And are you really using FMP instead of FMP24?
Freq section
P25 systems don't need any user-provided channel data.
Entering channels twice doesn't accomplish anything.
You haven't set any of the channel numbers. DSD+ can't trunk track if you don't tell it what channel numbers go with what frequencies.
bravo14
Polk County FL
I haven't ran FMP24 before.
I thought it had been twice since there is 2 different slots
I don't know the LCN or CH ID number.
slicerwizard
Toronto, Ontario
Then you're mixing parts of DSD+ 1.101 with parts of FL. That's asking for trouble.
The 1.101 docs (DSDPlus.txt) says one entry per DMR RF channel.
The control channel tells you the channel numbers.
bravo14
Polk County FL
The Control Channel for the Power Company doesn't give out the Channel Numbers for some odd reason.
I'll go back in the freq section to remove extra freqs.
thewraith2008
Looks like you have a CC but in that screenshot, there has not been any call activity.
You should see a channel # appear when that happens.
Must be a dead quite network.
Do you have the Fastlane (paid) version of DSDPlus or only the public released version (v1p101)?
bravo14
Polk County FL
I have the paid version.
thewraith2008
The screenshot shows FMP that's not the Fastlane version FMP24.
You need to be using FMP24 if you have the Fastlane version.
Also check version of DSDplus your pointing to. Check your .bat files.
Versions are displayed at startup in console or event window.
bravo14
Polk County FL
I open FMP24 and I tune into the freq I don't hear the Control Ch. or it doesn't see the Control Ch.
