Old 05-18-2018, 12:54 PM
bravo14's Avatar
Question DSDPlus Trunking question
Can I trunk track freqs on DSDPlus scan for freqs for a system or do I need to have sharp for control channel and run dsdplus?
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800 BCD536HP BCD436HP BCDSDS100
YouTube http://www.youtube.com/user/staugfl1991 (videos)
YouTube http://www.youtube.com/user/scannerfreak91 (Scanners)
Old 05-18-2018, 8:10 PM
Can you rephrase that.
For best results, with 2 dongles, your setup should be (using TCP):
FMP24 set up as CC
DSDPlus setup as CC
FMP24 set up as VC
DSDPlus setup as VC
CC (Control Channel) setup follows control activity
VC (Voice Channel) setup responds to CC and follows voice activity.
You still need to fill in the record files (.frequencies, .sites, .networks)
Old 05-18-2018, 8:43 PM
bravo14's Avatar
FMP24 set up as CC
DSDPlus setup as CC
FMP24 set up as VC
DSDPlus setup as VC
I do have 2 dongles. I do use the fmp cc/vc and dsdplus. Also have the tiles set up still no luck
Old 05-18-2018, 8:46 PM
Need more details. What system? What setup in the files have you done?
Old 05-18-2018, 10:14 PM
Are you asking about scanning to find frequencies?
Old 05-19-2018, 5:26 AM
bravo14's Avatar
I've put in the cap+ & Con+ system and the frequencies sites lcn and ota channels.
Old 05-19-2018, 5:27 AM
bravo14's Avatar
No I have the freqs just to need to scan them
Old 05-19-2018, 11:48 AM
Then you would put the freqs into a FMP(24) scanfile.
This format
770.50625 P25 DELAY=4 Toronto Emergency Services North C
769.93125 P25 DELAY=4 Toronto Emergency Services South C
Then run a batchfile similar to this...
SD+ Switches
: -fa Auto-detect all protocols / frame types except dPMR [-fa]
: -fd Decode D-STAR (no audio)
: -fn Decode NXDN4800 (Kenwood NEXEDGE and Icom IDAS)
: -fN Decode NXDN9600 (Kenwood NEXEDGE)
: -fr Decode DMR/MotoTRBO (TDMA inputs + both output slots)
: -f1 Decode P25 Phase 1
: -fx Decode X2-TDMA
: -fp Decode ProVoice
: -fm Enable dPMR decoding (no audio):FMP24-CC.bat:
:FMP24-CC.bat: ***"-fxxx.xxx"***
Start FMP24 -i1 -b9.5 -rc -P0.8 -g49.6 -s1 -o20001 -_1 -wsl000.40
SD-CC.bat:
Start DSDPlus -e -rc -f1 -i20001 -v4
:FMP24-VC.bat:
Start FMP24 -i2 -b9.5 -P0.8 -g49.6 -o20002 -rv -_1 -wsl250.40
SD-VC.bat:
Start DSDPlus -e -rv -f1 -i20002 -v4
of course change the variables to suit your needs.
Old 05-19-2018, 4:15 PM
bravo14's Avatar
Here is what I have in
cc.bat DSDPlus -rc -i3 -v3 -wsl400.2 -wss100.200 -wel0.1 -wcl0.445 -wes400.520 >>CC.log
fmp-cc.bat 4 1 20.0 452.625
fmp-vc.bat FMP 3 2 20.0 99.99999999
vc.bat DSDPlus -rv -Pwav -i2 -o1 -v3 -wsl400.210 -wss100.200 -wel172.522 -wcl528.0 >>VC.log
Freq section
; Regional Domestic Security Task Force
P25, BEE00.292, 1.14, 0, 769.25625, 799.25625, 0
P25, BEE00.292 1.14, 0, 770.28125, 800.28125, 0
P25, BEE00.292, 1.14, 0, 771.38125, 801.38125, 0
; PowerSouth Energy Cooperative
Con+, 164, 18, 0, 451.0625, 456.0625 0
Con+, 164, 2, 0, 461.6000, 466.6000 0
Con+, 164, 11, 0, 452.6250, 457.6250, 0
Con+, 164, 11, 0, 451.9250, 456.9250, 0
Con+, 164, 11, 0, 451.0750, 456.0750, 0
Con+, 164, 28, 0, 451.7500, 456.7500, 0
COn+, 164, 28, 0, 452.1000, 457.1000, 0
Con+, 164, 28, 0, 452.7250, 457.7250, 0
Old 05-20-2018, 1:03 AM
Do you really just have a bunch of numbers? And are you really using FMP instead of FMP24?
Freq section
P25 systems don't need any user-provided channel data.
Entering channels twice doesn't accomplish anything.
You haven't set any of the channel numbers. DSD+ can't trunk track if you don't tell it what channel numbers go with what frequencies.
Old 05-25-2018, 7:14 PM
bravo14's Avatar
I haven't ran FMP24 before.
I thought it had been twice since there is 2 different slots
I don't know the LCN or CH ID number.
Old 05-25-2018, 8:16 PM
Then you're mixing parts of DSD+ 1.101 with parts of FL. That's asking for trouble.
The 1.101 docs (DSDPlus.txt) says one entry per DMR RF channel.
The control channel tells you the channel numbers.
Old 05-25-2018, 8:41 PM
bravo14's Avatar
The Control Channel for the Power Company doesn't give out the Channel Numbers for some odd reason.
I'll go back in the freq section to remove extra freqs.
Old 05-25-2018, 9:38 PM
bravo14's Avatar
Here is a screen shot for the power company ch number
Old 05-25-2018, 11:39 PM
Looks like you have a CC but in that screenshot, there has not been any call activity.
You should see a channel # appear when that happens.
Must be a dead quite network.
Do you have the Fastlane (paid) version of DSDPlus or only the public released version (v1p101)?
Old 05-26-2018, 5:17 AM
bravo14's Avatar
I have the paid version.
Old 05-26-2018, 5:42 AM
The screenshot shows FMP that's not the Fastlane version FMP24.
You need to be using FMP24 if you have the Fastlane version.
Also check version of DSDplus your pointing to. Check your .bat files.
Versions are displayed at startup in console or event window.
Old 05-26-2018, 12:00 PM
As noted, because there's no traffic. So you're not missing anything...
Old 05-26-2018, 2:00 PM
bravo14's Avatar
Okay thanks
Old 05-26-2018, 2:01 PM
bravo14's Avatar
I open FMP24 and I tune into the freq I don't hear the Control Ch. or it doesn't see the Control Ch.
