LakevilleVFD
Hi All,
I feel like I'm beating an old drum here; having some trouble with DSD+ audio and errors trying to decode P25. See the attached capture from DSD+. The audio is just terrible, barely getting anything legible. I've tried with both VB-Cable and Virtual Audio Cable. VB-Cable only gives me "Input" in unitrunker as the output device, and "output" as the input device for DSD+ (?). Virtual audio cable Line 1 works, DSD+ is picking it up, but the output is mostly garbage. What I'm trying to do is have it legible so that I can hook in the FD e-dispatch system when we switch to TMR in the next week or so.
Here are the radios I'm using: https://www.amazon.ca/gp/product/B01HA642SW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
2 of. With full signal on control channel etc etc. Windows 7 Pro 64 bit.
EDIT: Reading through other posts, I found this from DRL-XM43, my audio sounds the same, with a little garbled voice: https://redirect.viglink.com/?forma...ps://1drv.ms/u/s!AlZVrkuVcHYMtjidcwuZ4nVHSuiA
Any insight is very much appreciated.
DT
DT
