Old 08-12-2018, 4:14 PM
Question DSD+ Event Log abbreviations
Hi,
When the event log screen shows "Enc Group call" and ends with "Alg=GP", does the "GP" indicate the system is using the General Privacy feature?
What are the other abbreviations that might be seen after "Alg=" ?
Old 08-12-2018, 11:26 PM
Don't think there is a GP algorithm. Double check your logs.
For DMR, there is BP (Basic Privacy) and EP (Enhanced Privacy)
Old 08-13-2018, 1:32 AM
Spitfire8520's Avatar
DSD+ occasionally had decode errors that are reflected in the event logs. This includes seeing things that don't make sense such as "Alg=GP" and incorrectly detecting "Enc Group call" on voice streams that are not encrypted. It also generates other odd quirks like incorrect talkgroup and radio IDs.
Mile-High Spitfire
RadioShack Pro-106 RadioShack Pro-652 RTL-SDR Unication G5 Uniden BCD436HP (On Loan)
MNN-250
Old 08-13-2018, 12:31 PM
Right you are Slicer. Unfortunately I typed GP from memory when I was thinking BP.
Does it indicate AES if they use it?
Old 08-13-2018, 2:32 PM
A bad decode isn't going to make up a nonexistent encryption algorithm.
Not for DMR. This system uses AES exclusively, but DSD+ always reports "EP".
https://www.radioreference.com/apps/db/?sid=9481
