LD723
- Joined
- Dec 8, 2016
- Messages
- 263
Does anyone know the correct command code for the sort of auto audio gain control for the fastlane version? I was using random command lines and the command -g-1 enabled the audio gain control thing but the weird part is that I can use any number with that command but if I remove the number for example that "1" it will not work so what is the exact correct command for it? And does the number matter? And I'm not talking about the manual gain control.
