The RadioReference.com Forums
-   Voice/Control Channel Decoding Software (https://forums.radioreference.com/voice-control-channel-decoding-software/)
-   -   FMP24 Issues in DSD+ Ver 2.113 (https://forums.radioreference.com/voice-control-channel-decoding-software/377099-fmp24-issues-dsd-ver-2-113-a.html)
jje64 09-24-2018 10:48 AM
I have loaded the latest FL version of DSD+ (2.113). When I attempt to run FMP24 it gives me an error that no configuration file is present. I attempted to write a config file based off of the FMP config file. It still will no run.
Is this a known issue? What am I doing wrong? It worked in the previous DSD+FL version, but I ahve not used the SW in a long time
simmsrep 09-24-2018 11:21 AM
Take a look at this youtube video. I ran into the same problem a while back and this video shows how to setup the config file.
https://www.youtube.com/watch?v=VNme...dex=131&t=595s
slicerwizard 09-24-2018 1:38 PM
There should be an FMP24.cfg file in one of your FL updates, probably the first one you got. Just unzip it to your DSD+ folder.
jje64 09-24-2018 2:12 PM
Thanks for the response to both posters. I will look at YT vid.
Slicerwizard, I was wondering if that was the issue. This was a fresh install and jumped from the 101 non Fl version right to 2.113. Maybe I need to load the intervening builds.
Will work it tonight
jje64 09-24-2018 7:29 PM
It looks like a dll was missing. libfft3w-3.dll. Other info on that here on RR. Grabbed the dll and FMP24 seems to run fine now. Time will tell
W2GLD 10-09-2018 12:08 AM
What .dll worked for you; I've been fighting with this for several months now and cannot find a workable .dll to use with the Airspy on Windows 10 x64; spent a few hours again today trying to get this to work, fails on the .dll because it's from a different PC and then errors out.
slicerwizard 10-09-2018 7:06 AM
Running 64 bit Windows 10.
FMPA says Airspy lib version = 1.0.8
airspy.dll size is 91,136 bytes.
Works fine.
You can extract it from https://airspy.com/?ddownload=3130
W2GLD 10-09-2018 11:46 AM
2 Attachment(s)
Works fine.
I've tried this already as well. I'm using, what I believe is the latest version of DSD+ Fast Lane, v2.113 and my airspy.dll is actually version 1.0.9.0; however, it doesn't seem to matter which airspy.dll version I use (1.0.8.0 or 1.0.9.0) I get the same error related to the libfftw3f-3.dll where this all began. I've attached two screenshots with this latest attempt using the airspy.dll version 1.0.8.0 you suggested. I am completely lost on how to resolve this and Google hasn't been much help either.
morfis 10-09-2018 1:37 PM
Isn't Machine Type Mismatch related to 32 bit and 64 bit? Had it occur on a work machine but not on my home ones. Work is 10 Professional...home is home
W2GLD 10-09-2018 3:42 PM
Well I'm using Windows 10 Professional x64; I've tried both example files I could located (x86 and x64) from this link (FFTW Installation on Windows) as well as another one, which I cannot recall but it was from another post here on RadioReference.com. Additionally, I also sent an email off to DSD+ FastLane as well. I'm open to just about any and all suggestions at this point on this.
I'm having another issue in this build of DSD+ FastLane as well with a Cap+ system and it not recognizing it's pseudo NetworkID I assigned and thus not calling the Sites and Frequencies from the files section when trying to decode; works great for Con+ and P25 systems but it never fills in the Cap+ information and I followed all the examples here on RadioReference.com I could find as well. The Cap+ system just reports as "Cap+ Site: 1 DCC: 1" so I setup a network called "Cap+, 9096, "Name of the System" and then the Sites file has "Cap+, 9096, 1, "Proving Grounds" followed by the frequencies, example: "Cap+, 9096, 1, 1, 462.3000, 467.3000, 0"; I assume I'd just doing something wrong, but I cannot figure out what exactly.
slicerwizard 10-09-2018 11:02 PM
The FL docs tell you to download ftp://ftp.fftw.org/pub/fftw/fftw-3.3.5-dll32.zip and extract the libfftw3f-3.dll file to your DSD+ folder. That's all you have to do. It's the largest file in the zip; its size is 2,391,615 bytes, so just make sure you're extracting the correct file.
Your screenshot says that Windows has an issue with your libusb-1.0.dll file, not with any other file. The libusb-1.0.dll file I have here, that is working fine with regular dongles and Airspys, is 95,744 bytes in size. It appears to be the same file that's found in https://www.dsdplus.com/dl/DSDPlusDLLs.zip
The frequency records belong in your DSDPlus.frequencies file, not the sites file.
W2GLD 10-10-2018 12:22 AM
3 Attachment(s)
First, yes I followed the docs and that's how I replaced the "libfftw3f-3.dll" whis is how I got to the error shown in the screenshot; prior to having this .dll I wasn't able to get this far. I have also confirmed, since this is a clean install that I have present the "libusb-1.0.dll" as well from the original package for DSD+ as you have noted and I still get this error upon startup; replaced it again this evening as you suggested, same error. I cannot get past this blocker.
As for the files. yes I know that these are all different files. As I stated, the "NetworkID" is in the "DSDPlus.networks" file. The site is in the "DSDPlus.sites" file and the frequencies are in the "DSDPlus.frequencies" file. I have attached the screenshots here as well; does not display the frequencies in the CC activity window no matter what I change them to; this isn't an issue for anything besides Cap+ systems.
W2GLD 10-10-2018 12:33 AM
Okay after some additional digging into this tonight it appears there is an issue with this build of DSD+ and the airspy.dll v1.0.9.0. It was suggested that I grab the dll's from the latest SDRSharp folder and copy them into DSD+ and now I can start FMPA all of a sudden. And now that DSD+ is working through FMPA, the Cap+ file issue is also resolved; interesting that using the DSDPlus.exe to monitor the control channel yields different results than when using it through the FMPA.exe; I have much to learn as I am still learning this package. Thanks for all of the suggestions everyone, much appreciated.
slicerwizard 10-10-2018 3:38 AM
Sounds like you were trying to use 64 bit DLLs.
Because those are 32 bit DLLs.
I assume you mean different results when using SDR# vs using FMPA.
From the DSD+ 2.8 docs:
when a TCP link from FMP24 or FMPA is used and Cap+ is detected, DSD+ will scan the entries in DSDPlus.frequencies for a Cap+ entry with a frequency value that matches the frequency that FMP24 or FMPA is tuned to; if a match is found, DSD+ will use the network ID value from that Cap+ frequency entry as the current system ID
No FMPA equals no system ID and no trunk tracking.
mrc333777 10-11-2018 4:06 PM
just got 2 new rtl-sdr blog v3. so i cleaned my folder to fresh start.
also my local barberton ohio / summit county changed their CC.
sometimes i get a BSI=CHANGEME in yellow, what does this mean?
slicerwizard 10-12-2018 4:30 AM
It means the techs didn't bother setting the proper BSI value.
mrc333777 10-12-2018 5:14 AM
hehe, okay...
anyone that has dual screens, mine are 24 inch and i made a nice little .bat file and this is my configuration for screen positions. just change the -i? value to your rtl-sdr device number and the -P? to your ppm i suppose.
d:
cd D:\RF\dvb\DSDPlus2p113
start FMP24 -rc -i2 -a1 -o20001 -P0 -f858.5125 -_1 -wsl11.-1040
start FMP24 -i3 -a1 -o20002 -P0 -f999.9999 -_1 -wsl260.-1040
start DSDPlus -Pwav -rv -i20002 -fa -v3 -O NUL -_1 -wsl700.-1040 -wss100.200 -wel11.-1890 -wcl500.-550
start DSDPlus -rc -i20001 -fa -v3 -O NUL -_1 -wsl500.-1040 -wss100.200 -wel560.-1890 -wcl600.-550
