Just curious. If you look at the command window (dos window, whatever you want to call it) while it is monitoring the control channel of a DMR Tier III site, it should show a SysCode (14 bits, binary display). For a particular site, could you:
List the SysCode that shows up in the command window - 1101xxxxxxxxxx
List what DSDPlus shows in its main window for the Network model, Network, Area ID, Site ID (ex: H2-1.6)
List whether its showing as DMR Tier III or DMR Tier III (MOT) ?
If you can get the Syscode and the network/site info in A and B, they should be from the same system. Please don't get a SysCode from one system for A and then produce network/site information from another monitored system in B. That'd be extremely confusing.
