DSD help
jrl44430
I am trying to monitor this but get errors. A screen shot is attached of the errors. Do I have a setting wrong? Thanks.
SpugEddy
Camden County South Jersey
What are you using to send the data to DSD?
That is to say, what software are you using to
tune in the frequency? SDR#, HDSDR, etc?
When I used SDRsharp, I had a helluva time tuning
in for DSD. It was tedious but you need to fool with the
gain, turn off all filtering, play with volume, until you get
it right
jrl44430
Do you need the discriminator audio or from the earphone jack? This unknown department is not on alot and the CW ID is to fast for me.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Discriminator audio is a must - nothing less for digital signals. Just record a raw audio file in DSDPlus by starting up DSDPLus and pressing 'R' to record raw audio. Record it for a minute or two. Then press "R" again to stop the recording of raw audio.
Find that raw audio file in your DSDPlus folder -- In case you have more than one raw audio file already, it will be the the latest timestamp. It'll look something like this:
DSDPlus-Raw-Input_2018-10-05@000444.wav
Make it available somewhere that you can provide a link to so that it can be downloaded by others.
jrl44430
Thanks for the help. The signal is weak today. The frequency is 151.67. I have not found anything in the FCC database. I'm in Trumbull County Ohio. Have checked in PA also since I'm not far from the boarder.
