OP25 and unitrunker are both decoding fine.. Are you sure your signal strength is good and you don't have any co-channel interference?
Yeah the signal is buster and no obvious interference. I even put on my trusty 700-800 Mhz bandpass filter and that didn't help.
I didn't try Unitrunker though -- I was using DSD+ FL...
I will say the audio doesn't sound "healthy" -- almost as if there's a signal problem but SDR# and the Airspy are fine. I can turn down the gain but that doesn't help.
I suppose it could be some weird signal path issue. I believe that site is in West Seattle..?
I'll have to give it a listen on the scanner in the car when I leave work.
