Grant County fire tac frequncies
ScanYak
Eastern Washington
In Grant County does any of the fire districts use the VHF tac frequencies? Or are they only heard on the MACC p25 system? I don't seem to hear traffic on the repeated or simplex VHF tac frequencies listed in the database.
ScanYak
RBMTS
Most all comms are on MACC. The VHF is probably used as a backup if the main trunking system should go down. If you are close to an active incident you may want to listen in on the 800Mhz state-ops frequencies. I don't know if the use them but worth a try.
ScanYak
Eastern Washington
The MACC 800 P25 fire TGs work great for all of the County for both dispatch and tac. The VHF dispatch Fire 1, 2 and 3 repeaters are simulcast with the MACC 800 sys. but I was curious if the tac channels were used. FCC database shows frequencies still licensed.
I'm pretty sure the simplex tac frequencies wouldn't function well with the trunk system.
ScanYak
