Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > West Virginia Radio Discussion Forum
West Virginia Radio Discussion Forum - Forum for discussing Radio Information in the State of West Virginia.
Closed Thread
  #2721 (permalink)
Old 07-15-2012, 7:01 AM
OldDeadOne's Avatar
Silent Key
With the heavy amount of talking on 5903,I get the assumption that they are doing some kind of EMS disaster training,I've been hearing them every day now. Also as we get nearer to the Boy Scouts thingie opening date,I believe more new talkgroups might be popping up,who knows Fayette county might finally bust the bubble and join in the SIRN fun.
Pro 106,Pro 2096,Uniden 396XT(sons)
Deafness sucks! Glad I can still hear!
Active scanner for new stuff SIRN
Slow learner for wanting to play prog metal guitar....
  #2722 (permalink)
Old 07-15-2012, 3:56 PM
wvscanner's Avatar
I have been in and out today. I heard them on Pax and the new tower over in that area (2-037). Also got around today to get my Raleigh County feed up for Beckley again today.
BC396T | BC396XT | PRO-197 | AOR8200 (tap)
  #2723 (permalink)
Old 07-15-2012, 4:17 PM
OldDeadOne's Avatar
Silent Key
I also got 5919,which is also new and not in the database,which I think is also a regional response team talkgroup.
  #2724 (permalink)
Old 07-16-2012, 3:45 PM
Been hearing TG 4433 coming over the Mingo county site today. Not sure what it's all about. Some mention of air units and ground units. Similar traffic on Troop5 SP/Logan. Marijuana field bust?
  #2725 (permalink)
Old 07-17-2012, 4:13 PM
hmoutdoors's Avatar
Broken digital signal on 9223 this afternoon. No voice just garble ?
  #2726 (permalink)
Old 07-17-2012, 5:04 PM
Bubba1661's Avatar
WV DB Admin
Default Tg 9223
Steve,
That TG is a encripted Radio Tech. It is at the bottom in the Radio Tech section.
Bubba1661
West Virginia Scanner's Group
  #2727 (permalink)
Old 07-17-2012, 5:30 PM
OldDeadOne's Avatar
Silent Key
The radio techs were talking about tea and crumpets :P I don't think I've ever heard a Radio Tech out in the open,I've always heard them encrypted
  #2728 (permalink)
Old 07-17-2012, 5:31 PM
OldDeadOne's Avatar
Silent Key
Glad you got that back up and running, Jeff
  #2729 (permalink)
Old 07-17-2012, 5:58 PM
hmoutdoors's Avatar
Thanks for clearing that up for me
  #2730 (permalink)
Old 07-18-2012, 9:01 PM
I'm having a little issue with setting up my Uniden 396. I think its an issue with the Band Plans that I'm looking at on the RR site.
Custom Uniden Frequency Tables:
Table 1:
Base: 452.0000
Space: 12.5
Offset: 380
Table 2:
Base: 460.0000
Space: 12.5
Offset: 570
I can see where I can add the Band Plans as a APCO25 but I don't see where you can set the offset.
If this is in the wrong thread please advise but I figured this was the best for support.
Thanks!!
  #2731 (permalink)
Old 07-18-2012, 9:45 PM
OldDeadOne's Avatar
Silent Key
I found this using google,don't know if you are doing this manually or not,check a few posts down,I hope this helps(I don't use a Uniden 396) http://forums.radioreference.com/sou...n-bcd396t.html
  #2732 (permalink)
Old 07-18-2012, 11:04 PM
wvscanner's Avatar
Table 1:
Base: 452.0000
Space: 12.5
Offset: 380
Table 2:
Base: 460.0000
Space: 12.5
Offset: 570
Thanks!!
On the IRP with 396 you will not enter the offset. Setup as a motorola and a P25 system. Enter your freq. make sure you have TG enter or have it set on search and that is it.
  #2733 (permalink)
Old 07-19-2012, 5:06 AM
OldDeadOne's Avatar
Silent Key
Thanks,Jeff for helping him with that since I don't have a 396
  #2734 (permalink)
Old 07-19-2012, 9:24 PM
Guys that worked perfect! Thanks alot - I guess I didn't wait for enough traffic to hear it. Can you answer the question as to why you do not or cannot enter the offset on this scanner? I have seen other places where you are supposed to enter an offset but when I program it I could never found it...always just brushed it under the rug but I would like to know a little more about it if you could explain it in a short version.
Thanks again!
  #2735 (permalink)
Old 07-19-2012, 11:57 PM
wvscanner's Avatar
Thanks again!
On the IRP the control channel provides all the info. Once program and the scanner had locked onto the data channel you can go thru the settings and see the offset. Again this is set by the data channel.
If you come across a motorola type 2, like the Federal DOC in this area you will have to set the offset. Its not provided in the data stream.
  #2736 (permalink)
Old 07-29-2012, 12:26 AM
OldDeadOne's Avatar
Silent Key
Hey Jess,is much of the Charleston Talkgroups active? It seems kind of quiet lately,dunno I haven't heard a peep the last couple of days or so,makes me think that storm did more damage than I thought.
  #2737 (permalink)
Old 07-29-2012, 12:53 AM
Bubba1661's Avatar
WV DB Admin
Thumbs up Charleston TG's
Well Bert I just got home and I see your still up. Today they had something BIG at the Capital and tonight they had fireworks, I listened to TG 6905 all day and night, it was some kind of security for this shindig. I just checked my counts and I had over 100 hits on it today. Kan Co uses 6120, 6150, 6121 alot. St.Albans and Nitro are full time on 6122 and 6130. So.Chas Fire is fulltime on 6136. So.Chas uses 6118 and 6115 some. Dunbar PD uses there 2 6114 to BS 0n. So yes there is pretty good activity on the IRP. WVSP keeps 9011 hot too.
Bubba1661
  #2738 (permalink)
Old 07-29-2012, 7:21 AM
Default Chas and S Chas TGs
Jess you just answered one of my questions as well. I was also going to ask you about Chas & S Chas. I see that S Chas has went back to VHF (I noticed a couple wks ago). I also was going to ask you about Chas. So far is the only active police TG the traffic division? (I guess 159.150 is still the primary freq) I see there are a lot of other TGs listed but I don't hear anything from them.
73s
Chad
Pro 197, GRE PSR-500 X2, GRE PSR-600, Whistler WS1040, Whistler WS1065 GRE PSR-300, Uniden BCT7 X2, Uniden BC60XLT. Many Icom and Kenwood amateur radios. 73s and God Bless
  #2739 (permalink)
Old 07-29-2012, 7:23 AM
OldDeadOne's Avatar
Silent Key
Hmm,either Malden is down,or I must've fiddled too much with something on my scanner.I usually listen to all those talkgroups either day or night. Thanks Jess for the help!
  #2740 (permalink)
Old 07-29-2012, 7:24 AM
OldDeadOne's Avatar
Silent Key
Chad so you've had silence too?
Closed Thread
