Time to update our WS1080 scanners
There's a new update for the EZScan application itself AND Firmware 2.8
Release notes:
Whistler EZ SCAN Digital
Handheld Trunking Scanner
Version 2.04 - June 3, 2015
Corrected issue where the DSP DAC Gain value was not being stored correctly.
Adjusted the DSP DAC Gain range to match the latest CPU firmware with a range of -10db to +2db. Values will be adjusted to the default value of -4db the first time the file is loaded into the PC Application or the scanner.
Corrected an issue where updates could not be completed when using a Verizon HotSpot for Internet connectivity.
Removed an error message (No Sites Selected) that appeared when a trunked system was selected during an import but no talkgroups or transmitter sites were selected for import.
CPU Firmware
Release Notes
Version 2.8 - June 3, 2015
DAC gain changes for digital "too loud" problem
EDACS ESK detection fixes
Fixes for password / alarm functions. Changes were not always preserved on power-down.
Release notes:
CPU Firmware
Release Notes
