dpm3
My 1080 sometimes (in some cases frequently) will stop on talkgroups on local (Seattle-Tacoma) P25 Phase II systems without any audio. These silent "pauses" will typically last from 5 to 7 seconds and in some cases noticeably longer. The LED "alert" that I have programmed will illuminate and the radio display shows the talkgroup, system and site info; but no audio, not even "open carrier". Every once in awhile, the radio will produce some audio after such a prolonged pause and before beginning scanning once more; but typically it simply returns to scanning and regular reception returns - until the next time this happens. This issue doesn't appear to occur on the other local trunked systems (Motorola Type II - e.g. King County). The settings on the radio are basically out-of-the-box. I doubt this is an issue with encryption as I understand the radio won't even stop on encrypted transmissions and these are talkgroups are typically not encrypted (e.g. Fire Dispatch). If someone has suggestions on what settings might resolve the issue, I welcome their being shared.
